09-13-2024, 11:55 PM
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO44
* - MISO: GPIO40
* - CS: GPIO39
* - RST: GPIO43
* - INT: GPIO41
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
// Define the W5500 Ethernet module pins with the new GPIO assignments
#define W5500_CS_PIN 39
#define W5500_RST_PIN 43
#define W5500_INT_PIN 41
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 44
#define W5500_MISO_PIN 40
IPAddress ip(192, 168, 3, 55); // Static IP address
IPAddress subnet(255, 255, 255, 0); // Subnet mask
IPAddress gateway(192, 168, 3, 1); // Default gateway
IPAddress dns(192, 168, 3, 1); // DNS server address
EthernetServer server(4196);
while (!Serial) {
digitalWrite(W5500_RST_PIN, LOW); // Reset the W5500 module
delay(100); // Wait for reset to complete
Ethernet.init(W5500_CS_PIN);
Serial.print("IP Address: ");
server.begin();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
server.write(c);
client.stop();
6-Ethernet-W5500.zip (Size: 1.25 KB / Downloads: 793)
6-Ethernet-W5500.ino.merged.zip (Size: 186.82 KB / Downloads: 792)
