[arduino code examples for A32 Pro]-07 Communication between ESP32-S3 and Tuya module
* Copyright (c) 2024 KinCony IoT (https://www.kincony.com)
* This Arduino program implements communication between ESP32-S3 and the Tuya module
* and responds according to predefined commands. Additionally, it uses an LED connected
* to GPIO45 to indicate the network status based on the Tuya module's response, and a button
* on GPIO21 to initiate a manual quick configuration (EZ mode).
* Functionality:
* 1. The ESP32-S3 communicates with the Tuya module via serial (UART).
* 2. The program listens for specific commands from the Tuya module, such as heartbeat, product info requests, work mode requests, and network status.
* 3. When the ESP32-S3 receives a heartbeat packet (0x55 0xAA 00 00 00 00 0xFF), it responds with a heartbeat response (0x55 0xAA 03 00 00 01 00 03).
* 4. When the ESP32-S3 receives a network status update, it controls an LED connected to GPIO45 to indicate the current state:
*    - Fast blink (every 250ms) indicates the device is in quick configuration mode (EZ mode).
*    - Slow blink (every 1500ms) indicates the device is in hotspot configuration mode (AP mode).
*    - Solid ON indicates the device is successfully connected to the cloud.
* 5. A button connected to GPIO21 is used to send a command to the Tuya module to start the quick configuration mode.
* Pin definitions:
* - TXD (ESP32 to Tuya module): GPIO15
* - RXD (Tuya module to ESP32): GPIO16
* - LED for network status indication: GPIO45
* - Button for starting quick configuration: GPIO21
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
// Define the GPIO pins for TXD and RXD used for serial communication with the Tuya module
#define TXD_PIN 15
#define RXD_PIN 16
#define BAUD_RATE 9600
// Define the GPIO for LED and Button
#define LED_PIN 45
#define BUTTON_PIN 21
// Define LED flash intervals (in milliseconds) for different states
#define FAST_FLASH_INTERVAL 250      // Fast blink for EZ mode
#define SLOW_FLASH_INTERVAL 1500     // Slow blink for AP mode
#define LONG_LIGHT_INTERVAL 10000    // Long light for cloud connection (simulating always ON)
// Variables to control LED state
bool ledState = LOW;                 // Tracks the current state of the LED
unsigned long previousMillis = 0;    // Used to track time for blinking the LED
unsigned long flashInterval = LONG_LIGHT_INTERVAL;  // Default interval (long ON)
// Heartbeat response: Tuya expects this response after sending a heartbeat
// Product info response with details (e.g., product ID, firmware version, etc.)
// Work mode response: Sent when the Tuya module asks for the current work mode
uint8_t workModeResponse[] = {0x55, 0xAA, 0x03, 0x02, 0x00, 0x00, 0x04};
// Network status response: Sent when the Tuya module asks for the network status
// Subsequent heartbeat response: Sent after the first heartbeat response
// Command to start quick configuration (EZ mode) when the button is pressed
uint8_t quickConfigCommand[] = {0x55, 0xAA, 0x03, 0x05, 0x00, 0x01, 0x00, 0x08};
  // Initialize the GPIO for LED and button
  pinMode(LED_PIN, OUTPUT);       // Set the LED pin as output
  pinMode(BUTTON_PIN, INPUT_PULLUP); // Use internal pull-up resistor for the button
  // Handle LED blinking based on the current flash interval
  unsigned long currentMillis = millis();  // Get the current time
  if (currentMillis - previousMillis >= flashInterval) {
    previousMillis = currentMillis;        // Update the time tracker
    ledState = !ledState;                  // Toggle the LED state
    digitalWrite(LED_PIN, ledState);       // Update the LED state
  // Check if the button is pressed (active low)
  if (digitalRead(BUTTON_PIN) == LOW) {
    Serial.println("Button pressed, sending quick config command...");
    sendPacket(quickConfigCommand, sizeof(quickConfigCommand));  // Send quick config command
    delay(500);  // Debounce delay to avoid multiple triggers
  // Check if there is any data available from the Tuya module
  if (tuyaSerial.available()) {
    uint8_t incomingPacket[7];  // Array to store the received packet
    size_t bytesRead = tuyaSerial.readBytes(incomingPacket, 7); // Read 7 bytes from Tuya module
      if (bytesRead < 7) {
        delay(50); // Wait briefly to receive the remaining bytes
          if (bytesRead >= 7) break;
      // If the packet is still incomplete, discard it
      if (bytesRead < 7) return;
      // Process the received packet
    } else {
      // If the header is invalid, discard the packet
  // Small delay to prevent CPU overload
  delay(100);
// Function to process the received packet from Tuya module and send appropriate responses
  // Ensure the packet size is correct and the header is valid
    // Check the command byte (packet[2]) to determine the type of request
    switch (packet[2]) {
      case 0x00:
        // Heartbeat request
          sendPacket(heartBeatResponse, sizeof(heartBeatResponse));  // Send heartbeat response
        break;
      case 0x01:
        // Product info request
        sendPacket(productInfoResponse, sizeof(productInfoResponse));  // Send product info response
        break;
      case 0x02:
        // Work mode request
        sendPacket(workModeResponse, sizeof(workModeResponse));  // Send work mode response
        break;
      case 0x03:
        // Network status request
        sendPacket(netStatusResponse, sizeof(netStatusResponse));  // Send network status response
        // Change LED flash pattern based on network status (packet[6])
        if (packet[6] == 0x00) {
          flashInterval = FAST_FLASH_INTERVAL;  // Set LED to fast blink for EZ mode
        } else if (packet[6] == 0x01) {
          flashInterval = SLOW_FLASH_INTERVAL;  // Set LED to slow blink for AP mode
        } else if (packet[6] == 0x04) {
          flashInterval = LONG_LIGHT_INTERVAL;  // Set LED to long ON for cloud connection
          digitalWrite(LED_PIN, HIGH);          // Ensure LED is ON
        break;
      default:
        break;
// Function to send a response packet to the Tuya module
  // Send the packet via UART to the Tuya module
  // Debug: Print the sent packet for logging purposes
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
.zip   7-tuya-wifi-config.zip (Size: 2.89 KB / Downloads: 437)
.zip   7-tuya-wifi-config.ino.merged.zip (Size: 182.85 KB / Downloads: 424)
