09-14-2024, 12:06 AM
* This Arduino program controls the GP8403 DAC I2C chip using an ESP32-S3 board.
* The program sets the DAC outputs for two channels:
* - Channel 0 (CH0) outputs 5V.
* - Channel 1 (CH1) outputs 10V.
* The I2C communication is handled using the Wire library, and the SDA and SCL pins
* are custom defined as GPIO11 (SDA) and GPIO10 (SCL).
* GP8403 I2C address: 0x58
#include "DFRobot_GP8403.h"
// Initialize the GP8403 DAC object with the I2C address 0x58
DFRobot_GP8403 dac(&Wire, 0x58);
// Start serial communication for debugging purposes
// Initialize I2C communication with custom SDA and SCL pins
Wire.begin(11, 10); // SDA = GPIO11, SCL = GPIO10
// Try to initialize the DAC, retry if initialization fails
while(dac.begin() != 0) {
Serial.println("Initialization failed, retrying...");
delay(1000); // Wait for 1 second before retrying
// If initialization succeeds
Serial.println("Initialization successful!");
// Set the DAC output range to 10V (this setting applies to both channels)
dac.setDACOutRange(dac.eOutputRange10V);
// Set the output for DAC channel 0 to 5V
// Range for 10V mode is 0-10000, so 5000 represents 5V
dac.setDACOutVoltage(5000, 0); // Set CH0 to 5V
Serial.println("Channel 0 set to 5V");
// Set the output for DAC channel 1 to 10V
dac.setDACOutVoltage(10000, 1); // Set CH1 to 10V
Serial.println("Channel 1 set to 10V");
// Store the data in the chip's non-volatile memory so it persists after power-off
dac.store();
Serial.println("DAC values stored in memory");
// No need to continuously write the values, the DAC holds the last set value
9-dac-GP8403.zip (Size: 975 bytes / Downloads: 349)
9-dac-GP8403.ino.merged.zip (Size: 187.92 KB / Downloads: 397)
