[arduino code examples for B16M]-07 how to DS3231 RTC clock
* DS3231 RTC with Arduino
*    Set date and time command example: D2024-09-19T11:50:22
*    print current date and time command: current time
* Hardware Connections:
* - SDA: GPIO 38
* - SCL: GPIO 39
#include <DS3231.h>
#include <Wire.h>
typedef struct
  byte year;    // Last two digits of the year, library adds 2000.
  byte month;
  byte day;
  byte hour;
  byte minute;
  byte second;
} MY_DATE_STR;
#define OPEN_RLY_DATA    26
#define OPEN_RLY_MONTH   4
#define CLOSE_RLY_DATA   2
#define CLOSE_RLY_MONTH  5
// Define pin connections
#define SDA_PIN   38
#define SCL_PIN   39
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static void PrintfCurTime()
  Serial.print(year);
  Serial.print("-");
  Serial.print("-");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
static void GetSerialCmd()
  if (Serial.available() > 0)
    delay(100);
    while (num_read--)
  else return;
  serial_cmd_rcv.trim();
    PrintfCurTime();
    return;
  Serial.print("D index: ");
  Serial.print(indexof_d);
  Serial.print(" T index: ");
  Serial.println(indexof_t);
    return;
  rtc.setDate(my_date_str.day);
  Serial.println("Time set.");
  PrintfCurTime();
  while (Serial.read() >= 0) {}
  GetSerialCmd();
.zip   7-DS3231-RTC.zip (Size: 1.56 KB / Downloads: 490)
.zip   7-DS3231-RTC.ino.merged.zip (Size: 191.38 KB / Downloads: 484)
