[arduino code examples for F16]-02 Read digital input ports state
* Description:
* This Arduino program reads the state of a 16-channel PCF8575 I/O expander
* each pin is represented as a bit in a 16-bit value, where each bit corresponds
* Pin Definitions:
* - SDA: GPIO 21
* - SCL: GPIO 22
* - PCF8575 I2C Address: 0x24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C address
PCF8575 pcf8575_IN1(0x24); // The I2C address of the PCF8575
    pcf8575_IN1.begin(); // Initialize the PCF8575
    Serial.println("KinCony F16 16 channel input state 0:ON  1:OFF");
    uint16_t state = 0;
    for (int pin = 0; pin < 16; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   2-digital-input.zip (Size: 839 bytes / Downloads: 456)
.zip   2-digital-input.ino.merged.zip (Size: 187.5 KB / Downloads: 438)
Hi! I bought f16, before I was using A8s but Now Switched to F16 for my project. I am confused for f16 libraries. As I cannot find the "pcf8575" and "U8g2lib" libraries used in examples of f16. Can you share these libraries. Also, Kindly share the schematic of F16 as It would be helpful for my project. Thanks.
already repied in your another thread.
