Threads: 1,576
digital input =24v, means logical "0", NOT trigger.
digital input =0v, means logical "1", trigger.
Threads: 2
Do you plan new version where the trigger is +24V?
Threads: 1,576
10-04-2024, 12:43 PM
(This post was last modified: 10-04-2024, 12:44 PM by admin.)
if you use KCS firmware, these is an option "inverted" in "INPUT" webpage , just enable it, then the logical will be switched.
Threads: 2
Unfortunately it doesn´t work. The change of logic works only when I send GND to digital input. But when I send +24V to the same digital input, no reaction. Maybe my board is wrong. Rev. 1.1
Threads: 1,576
what software you are using? KC868-AI work for home assistant?
Threads: 2
in KC868-AI is KCS version: 2.2.4
at home I use Loxone.
Threads: 1,576
if you are using KCS firmware, i have already told you how to do.
