How to setup S3 Core Board + DO8 + HAv2 with Physical Switch using ESPHome?
Hi ,
Below is my product list
S3 core Board
DO8 relay board
HAv2
I have successfully config DO8 and HAv2 with ESPHome in Home Assistant , please see attached photos.
Please help me to modify my yaml to use HAv2 and Siemens to control the relay on DO8
attached is my yaml
.txt   s3-core.txt (Size: 4.02 KB / Downloads: 490)
Thanks,
when you press switch , the binary sensor state will update in home assistant, that means config OK.
second, you just create AUTOMATION in home assistant, IF binary sensor state ON THEN DO8 relay TOGGLE
(10-06-2024, 12:40 PM)admin Wrote: when you press switch , the binary sensor state will update in home assistant, that means config OK.
 please see my log
when I press the switch I can see log output , but the binary sensor state do not update .
How can I modify my config ?
HAv2 config as Latch switch and default address , rising edge and falling edge as EvtTog
Please help thanks.
