A32 Pro ESPHome yaml include RS485 modbus temperature humidity sensor
here we use RS485 long distance sensor connect with A32 Pro controller using A and B.
the sensor default setting is 9600bps, RS485 address is 1
we can use USB-RS485 adapter connect PC with sensor , monitor the sensor value, or maybe you want change the sensor address and baud rate, so just use PC software to set. Then we can let sensor connect to A32 Pro's RS485 port directly.
mainly add these code for modbus:
uart:
  - id: uart_modbus
    baud_rate: 9600
    tx_pin: 9
    rx_pin: 8
# Config Modbus
modbus:
  uart_id: uart_modbus
modbus_controller:
  - id: modbus_sensor
    address: 0x01  # device address
    modbus_id: modbus1
  - platform: modbus_controller
    modbus_controller_id: modbus_sensor
    name: "RS485 Temperature Sensor"
    address: 0x0000
    register_type: holding
    value_type: U_WORD
    unit_of_measurement: "°C"
    accuracy_decimals: 1
    filters:
      - lambda: if (x < 10000) return x * 0.1; else return -1 * (x - 10000) * 0.1;
    name: "RS485 Humidity Sensor"
    address: 0x0001
    value_type: U_WORD
    unit_of_measurement: "%"
    filters:
      - multiply: 0.1
whole ESPHome ymal code:
  friendly_name: a32-Pro-arduino
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
      - "-DWIFI_CONTROL_SELF_MODE=0"
external_components:
  - source:
      type: git
      ref: v1.2.0
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# logger:
  encryption:
    key: "fBpihEYPVlfKaE4ZIcY0uRcJ134u7DBKzzskk994+Lw="
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO44
  miso_pin: GPIO40
  cs_pin: GPIO39
  interrupt_pin: GPIO41
  reset_pin: GPIO43
uart:
  - id: uart_modbus
    baud_rate: 9600
    tx_pin: 9
    rx_pin: 8
  - id: tuya_mcu_uart
    baud_rate: 9600
    tx_pin: 15
    rx_pin: 16
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: fwy7fk4mzay3kern
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 21
  wifi_led_pin: 45
# Config Modbus
modbus:
modbus_controller:
  - id: modbus_sensor
    modbus_id: modbus1
   - id: bus_a
     sda: 11
     scl: 10
     frequency: 400kHz
xl9535:
  - id: xl9535_hub_out1 # for output channel 1-16
    address: 0x21
  - id: xl9535_hub_out2 # for output channel 17-32
    address: 0x22
  - id: xl9535_hub_in1 # for input channel 1-16
    address: 0x24
  - id: xl9535_hub_in2 # for input channel 17-32
    address: 0x25
pcf8574:
  - id: 'pcf8574_in_3'  # for input channel 33-40
    address: 0x23
    pin: 45
    name: A32 Pro Switch01
      xl9535: xl9535_hub_out1
      mode: OUTPUT
  - platform: tuya_wifi_mcu
    name: A32 Pro Switch01 Tuya
    dp_id: 101
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "a32_pro_switch01"
    name: A32 Pro Switch02
      number: 1
      mode: OUTPUT
    name: A32 Pro Switch02 Tuya
    dp_id: 102
    internal: true
    bind_switch_id: "a32_pro_switch02"
    name: A32 Pro Switch03
      number: 2
      mode: OUTPUT
    name: A32 Pro Switch03 Tuya
    dp_id: 103
    internal: true
    bind_switch_id: "a32_pro_switch03"
    name: A32 Pro Switch04
      number: 3
      mode: OUTPUT
    name: A32 Pro Switch04 Tuya
    dp_id: 104
    internal: true
    bind_switch_id: "a32_pro_switch04"
    name: A32 Pro Switch05
      number: 4
      mode: OUTPUT
    name: A32 Pro Switch05 Tuya
    dp_id: 105
    internal: true
    bind_switch_id: "a32_pro_switch05"
    name: A32 Pro Switch06
      number: 5
      mode: OUTPUT
    name: A32 Pro Switch06 Tuya
    dp_id: 106
    internal: true
    bind_switch_id: "a32_pro_switch06"
    name: A32 Pro Switch07
      number: 6
      mode: OUTPUT
    name: A32 Pro Switch07 Tuya
    dp_id: 107
    internal: true
    bind_switch_id: "a32_pro_switch07"
    name: A32 Pro Switch08
      number: 7
      mode: OUTPUT
    name: A32 Pro Switch08 Tuya
    dp_id: 108
    internal: true
    bind_switch_id: "a32_pro_switch08"
    name: A32 Pro Switch09
      number: 10
      mode: OUTPUT
    name: A32 Pro Switch09 Tuya
    dp_id: 109
    internal: true
    bind_switch_id: "a32_pro_switch09"
    name: A32 Pro Switch10
      number: 11
      mode: OUTPUT
    name: A32 Pro Switch10 Tuya
    dp_id: 110
    internal: true
    bind_switch_id: "a32_pro_switch10"
    name: A32 Pro Switch11
      number: 12
      mode: OUTPUT
    name: A32 Pro Switch11 Tuya
    dp_id: 111
    internal: true
    bind_switch_id: "a32_pro_switch11"
    name: A32 Pro Switch12
      number: 13
      mode: OUTPUT
    name: A32 Pro Switch12 Tuya
    dp_id: 112
    internal: true
    bind_switch_id: "a32_pro_switch12"
    name: A32 Pro Switch13
      number: 14
      mode: OUTPUT
    name: A32 Pro Switch13 Tuya
    dp_id: 113
    internal: true
    bind_switch_id: "a32_pro_switch13"
    name: A32 Pro Switch14
      number: 15
      mode: OUTPUT
    name: A32 Pro Switch14 Tuya
    dp_id: 114
    internal: true
    bind_switch_id: "a32_pro_switch14"
    name: A32 Pro Switch15
      number: 16
      mode: OUTPUT
    name: A32 Pro Switch15 Tuya
    dp_id: 115
    internal: true
    bind_switch_id: "a32_pro_switch15"
    name: A32 Pro Switch16
      number: 17
      mode: OUTPUT
    name: A32 Pro Switch16 Tuya
    dp_id: 116
    internal: true
    bind_switch_id: "a32_pro_switch16"
    name: A32 Pro Switch17
      xl9535: xl9535_hub_out2
      mode: OUTPUT
    name: A32 Pro Switch17 Tuya
    dp_id: 117
    internal: true
    bind_switch_id: "a32_pro_switch17"
    name: A32 Pro Switch18
      number: 1
      mode: OUTPUT
    name: A32 Pro Switch18 Tuya
    dp_id: 118
    internal: true
    bind_switch_id: "a32_pro_switch18"
    name: A32 Pro Switch19
      number: 2
      mode: OUTPUT
    name: A32 Pro Switch19 Tuya
    dp_id: 119
    internal: true
    bind_switch_id: "a32_pro_switch19"
    name: A32 Pro Switch20
      number: 3
      mode: OUTPUT
    name: A32 Pro Switch20 Tuya
    dp_id: 120
    internal: true
    bind_switch_id: "a32_pro_switch20"
    name: A32 Pro Switch21
      number: 4
      mode: OUTPUT
    name: A32 Pro Switch21 Tuya
    dp_id: 121
    internal: true
    bind_switch_id: "a32_pro_switch21"
    name: A32 Pro Switch22
      number: 5
      mode: OUTPUT
    name: A32 Pro Switch22 Tuya
    dp_id: 122
    internal: true
    bind_switch_id: "a32_pro_switch22"
    name: A32 Pro Switch23
      number: 6
      mode: OUTPUT
    name: A32 Pro Switch23 Tuya
    dp_id: 123
    internal: true
    bind_switch_id: "a32_pro_switch23"
    name: A32 Pro Switch24
      number: 7
      mode: OUTPUT
    name: A32 Pro Switch24 Tuya
    dp_id: 124
    internal: true
    bind_switch_id: "a32_pro_switch24"
    name: A32 Pro Switch25
      number: 10
      mode: OUTPUT
    name: A32 Pro Switch25 Tuya
    dp_id: 125
    internal: true
    bind_switch_id: "a32_pro_switch25"
    name: A32 Pro Switch26
      number: 11
      mode: OUTPUT
    name: A32 Pro Switch26 Tuya
    dp_id: 126
    internal: true
    bind_switch_id: "a32_pro_switch26"
    name: A32 Pro Switch27
      number: 12
      mode: OUTPUT
    name: A32 Pro Switch27 Tuya
    dp_id: 127
    internal: true
    bind_switch_id: "a32_pro_switch27"
    name: A32 Pro Switch28
      number: 13
      mode: OUTPUT
    name: A32 Pro Switch28 Tuya
    dp_id: 128
    internal: true
    bind_switch_id: "a32_pro_switch28"
    name: A32 Pro Switch29
      number: 14
      mode: OUTPUT
    name: A32 Pro Switch29 Tuya
    dp_id: 129
    internal: true
    bind_switch_id: "a32_pro_switch29"
    name: A32 Pro Switch30
      number: 15
      mode: OUTPUT
    name: A32 Pro Switch30 Tuya
    dp_id: 130
    internal: true
    bind_switch_id: "a32_pro_switch30"
    name: A32 Pro Switch31
      number: 16
      mode: OUTPUT
    name: A32 Pro Switch31 Tuya
    dp_id: 131
    internal: true
    bind_switch_id: "a32_pro_switch31"
    name: A32 Pro Switch32
      number: 17
      mode: OUTPUT
    name: A32 Pro Switch32 Tuya
    dp_id: 132
    internal: true
    bind_switch_id: "a32_pro_switch32"
    name: A32 Pro DI01
    on_press:
      then:
        - switch.toggle: a32_pro_switch01
      xl9535: xl9535_hub_in1
      mode: INPUT
    name: A32 Pro DI01 Tuya
    dp_id: 133
    bind_binary_sensor_id: a32_pro_di01
    internal: true
    name: A32 Pro DI02
      number: 1
      mode: INPUT
    name: A32 Pro DI02 Tuya
    dp_id: 134
    bind_binary_sensor_id: a32_pro_di02
    internal: true
    name: A32 Pro DI03
      number: 2
      mode: INPUT
    name: A32 Pro DI03 Tuya
    dp_id: 135
    bind_binary_sensor_id: a32_pro_di03
    internal: true
    name: A32 Pro DI04
      number: 3
      mode: INPUT
    name: A32 Pro DI04 Tuya
    dp_id: 136
    bind_binary_sensor_id: a32_pro_di04
    internal: true
    name: A32 Pro DI05
      number: 4
      mode: INPUT
    name: A32 Pro DI06
      number: 5
      mode: INPUT
    name: A32 Pro DI07
      number: 6
      mode: INPUT
    name: A32 Pro DI08
      number: 7
      mode: INPUT
    name: A32 Pro DI09
      number: 10
      mode: INPUT
    name: A32 Pro DI10
      number: 11
      mode: INPUT
    name: A32 Pro DI11
      number: 12
      mode: INPUT
    name: A32 Pro DI12
      number: 13
      mode: INPUT
    name: A32 Pro DI13
      number: 14
      mode: INPUT
    name: A32 Pro DI14
      number: 15
      mode: INPUT
    name: A32 Pro DI15
      number: 16
      mode: INPUT
    name: A32 Pro DI16
      number: 17
      mode: INPUT
    name: "A32 Pro TMP1"
      number: 1
    name: "A32 Pro TMP2"
      number: 2
    name: "A32 Pro DL"
    name: "A32 Pro DTUYA"
      number: 21
    name: A32 Pro DI17
      xl9535: xl9535_hub_in2
      mode: INPUT
    name: A32 Pro DI18
      number: 1
      mode: INPUT
    name: A32 Pro DI19
      number: 2
      mode: INPUT
    name: A32 Pro DI20
      number: 3
      mode: INPUT
    name: A32 Pro DI21
      number: 4
      mode: INPUT
    name: A32 Pro DI22
      number: 5
      mode: INPUT
    name: A32 Pro DI23
      number: 6
      mode: INPUT
    name: A32 Pro DI24
      number: 7
      mode: INPUT
    name: A32 Pro DI25
      number: 10
      mode: INPUT
    name: A32 Pro DI26
      number: 11
      mode: INPUT
    name: A32 Pro DI27
      number: 12
      mode: INPUT
    name: A32 Pro DI28
      number: 13
      mode: INPUT
    name: A32 Pro DI29
      number: 14
      mode: INPUT
    name: A32 Pro DI30
      number: 15
      mode: INPUT
    name: A32 Pro DI31
      number: 16
      mode: INPUT
    name: A32 Pro DI32
      number: 17
      mode: INPUT
    name: A32 Pro DI33
      pcf8574: pcf8574_in_3
      mode: INPUT
    name: A32 Pro DI34
      number: 1
      mode: INPUT
    name: A32 Pro DI35
      number: 2
      mode: INPUT
    name: A32 Pro DI36
      number: 3
      mode: INPUT
    name: A32 Pro DI37
      number: 4
      mode: INPUT
    name: A32 Pro DI38
      number: 5
      mode: INPUT
    name: A32 Pro DI39
      number: 6
      mode: INPUT
    name: A32 Pro DI40
      number: 7
      mode: INPUT
gp8403:
  voltage: 10V
output:
  - platform: gp8403
    gp8403_id: my_gp8403
    channel: 0
  - platform: gp8403
    channel: 1
light:
  - platform: monochromatic
    name: "A32 Pro-DAC-0"
    output: gp8403_output_1
    gamma_correct: 1.0
    name: "Tuya A32 Pro-DAC-0"
    # bind other light, sync state
    bind_light_id: a32_pro_dac_0
    dp_id: 173
    internal: true
    gamma_correct: 1.0
    name: "A32 Pro-DAC-1"
    output: gp8403_output_2
    gamma_correct: 1.0
    name: "Tuya A32 Pro-DAC-1"
    bind_light_id: a32_pro_dac_1
    dp_id: 174
    internal: true
    gamma_correct: 1.0
  - platform: adc
    pin: 7
    name: "A32 Pro A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "A32 Pro A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 5
    name: "A32 Pro A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "A32 Pro A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
    address: 0x0000
    value_type: U_WORD
    filters:
    address: 0x0001
    value_type: U_WORD
    filters:
      - multiply: 0.1
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "A32 Pro");
yaml file download:
.txt   A32_Pro-ESPHome_arduino_type_RS485_MODBUS_SENSOR.txt (Size: 23.44 KB / Downloads: 507)
RS485 sensor config PC software:
.zip   RS485-sensor-PC-tool.zip (Size: 4.08 MB / Downloads: 648)
Will this sensor work with Home Assistant connected in A+B?
What is the code for yaml?
sure, it support home assistant, if your sever have RS485 port, you can connect directly.
yaml file already showed in this thread. it's same, just modify configure.yaml for home assistant.
The yamp code is the same you have here on this thread?
only need change RS485 rxd,txd pin define number.
(12-15-2024, 06:31 AM)admin Wrote: only need change RS485 rxd,txd pin define number.
Is there somewhere a tutorial for yaml code as I do not know how yaml works?
do you have a own server computer installed home assistant?
Yes, home assistant installed already and running. AIO board used for automation.
what's your server? it's a PC? or it's a KinCony server16 controller? we need details.
It is a raspbery pi 5 8gb running home assistant on docker.
