Ghost trigger
Question
Hi,
I have implemented a kc-868-a64 in my home. It works great. It is integrated with Home Assistant to do some automation but the kc-868-a64 works on itself (see config below)
But I have a problem. Sometime when a push button is pressed, the configured light goes on BUT an other, not configured light sometimes also goes on.
I have this for some push buttons, not all.
I tried to troubleshoot it but I can't find the issue.
Is there any way to troubleshoot this issue or is this a known issue ?
I have impulse relays so most of the outputs will turn off again.
My ESP HOME config is attached (I have redacted some fields)
.txt   a64.txt (Size: 37.25 KB / Downloads: 372)
can you take a video of your problem, send to whatsapp number: +86-15381188302
I know how to take a video but the issue is there sometimes, not always. The problem is not consistently reproducible.
Is there any way to do some logging and do you know what to log ?
Greetings,
Kris Boeckx.
can you download KCS firmware to KC868-A64 for a testing?
just not use ESPHome, use KCS and config digital input ports trigger OUTPUT by IFTTT. here is online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
(10-24-2024, 11:51 PM)admin Wrote: can you download KCS firmware to KC868-A64 for a testing?
No I can't. The board is in production.
I need integration in Home Assistant.
If I have time, I will configure a "syslog" server and send all the messages to the syslog server.
I hope I can find what's wrong.
Greeting !
