Threads: 1
Hi, does the B16M board support dimming LEDs with 20kHz PWM (up to 10A/channel load)? If not, what is the maximum PWM frequency that can be used without overheating/burning the MOSFET/driver/microcontroller/etc?
Regards,
Robert
Threads: 1,393
10-20-2024, 02:16 AM
(This post was last modified: 10-20-2024, 03:07 AM by admin.)
sorry, B16M mosfet output can't use for PWM output, because of ESP32-S3 conenct with i2c PCF8575 extender chip , then connect with 10A mosfet. Use ON/OFF is better. But B16M have free GPIOs on board, that can use for PWM output, just without driver.
if you want to use dimmer , suggest you chose KC868-AP or KC868-D16 dimmer controller.
Threads: 1,393
we have ESP32 board can output PWM, but without "a couple of Amperes load". Maybe you need to add your own driver.
KC868-D16 is dc 0-10v output dimmer controller, NOT output PWM, it's made by ARM STM32 CPU, not use ESP32 CPU.
Threads: 1,393
Do you use for DC load or AC load? can you list load type in details.
Threads: 1,393
why not use KC868-AP? it have 10A driver on PCB. it can drive your LED strip.
if you think power is not enough. you can use KC868-D16 + LED Driver (MAX have 250W version), it enough for LED strip to use.
