10-22-2024, 12:54 AM
ESP32 I2S Audio Test
This code generates a simple sine wave to test the MAX98357A amplifier output.
// Include I2S driver
#include <driver/i2s.h>
#include <math.h>
// Connections to MAX98357A amplifier
#define I2S_DOUT 8
#define I2S_BCLK 7
#define I2S_LRC 6
// Use I2S Processor 0
#define I2S_PORT I2S_NUM_0
// Sample rate and wave parameters
const int sampleRate = 44100;
const float frequency = 440.0; // Frequency of the sine wave (A4 note)
const int amplitude = 3000; // Amplitude of the sine wave
void i2s_install() {
// Set up I2S Processor configuration for TX only
const i2s_config_t i2s_config = {
.mode = i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_TX),
.sample_rate = sampleRate,
.bits_per_sample = i2s_bits_per_sample_t(16),
.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
.communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_STAND_I2S),
.intr_alloc_flags = 0,
.dma_buf_count = 8,
.dma_buf_len = 64,
.use_apll = false
i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
void i2s_setpin() {
// Set I2S pin configuration for output (amp)
const i2s_pin_config_t pin_config = {
.bck_io_num = I2S_BCLK,
.ws_io_num = I2S_LRC,
.data_out_num = I2S_DOUT,
.data_in_num = I2S_PIN_NO_CHANGE
i2s_set_pin(I2S_PORT, &pin_config);
// Set up Serial Monitor
Serial.println("Generating sine wave on MAX98357A amplifier");
// Set up I2S
i2s_install();
i2s_setpin();
i2s_start(I2S_PORT);
// Buffer to hold the audio data
int16_t buffer[64];
// Generate sine wave and write it to I2S buffer
for (int i = 0; i < 64; i++) {
float sample = sinf(2.0f * M_PI * frequency * i / sampleRate);
buffer[i] = (int16_t)(sample * amplitude); // Convert float to 16-bit integer
// Send the buffer to the I2S amplifier
size_t bytesWritten;
i2s_write(I2S_PORT, &buffer, sizeof(buffer), &bytesWritten, portMAX_DELAY);
AS-Speaker-Simple-wave.zip (Size: 1.09 KB / Downloads: 876)
AS-Speaker-Simple-wave.ino.merged.zip (Size: 192.24 KB / Downloads: 805)
