[arduino code examples for AS]-04 how to output dynamic wave to speaker by MAX98357A
  ESP32 I2S Audio Test with Dynamic Frequency and Amplitude
  This code generates a sine wave with changing frequency and amplitude
  to test the MAX98357A amplifier output.
// Include I2S driver
#include <driver/i2s.h>
#include <math.h>
// Connections to MAX98357A amplifier
#define I2S_DOUT  8
#define I2S_BCLK  7
#define I2S_LRC   6
// Use I2S Processor 0
#define I2S_PORT I2S_NUM_0
// Sample rate and initial parameters
const int sampleRate = 44100;
const float baseFrequency = 440.0;  // Base frequency (A4 note)
const int baseAmplitude = 3000;     // Base amplitude
const float frequencyStep = 5.0;    // Frequency change rate
const int amplitudeStep = 50;       // Amplitude change rate
// Variables to control dynamic frequency and amplitude
float currentFrequency = baseFrequency;
int currentAmplitude = baseAmplitude;
int direction = 1;  // To control increase or decrease of frequency and amplitude
void i2s_install() {
  // Set up I2S Processor configuration for TX only
  const i2s_config_t i2s_config = {
    .mode = i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_TX),
    .sample_rate = sampleRate,
    .bits_per_sample = i2s_bits_per_sample_t(16),
    .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
    .communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_STAND_I2S),
    .intr_alloc_flags = 0,
    .dma_buf_count = 8,
    .dma_buf_len = 64,
    .use_apll = false
  i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
void i2s_setpin() {
  // Set I2S pin configuration for output (amp)
  const i2s_pin_config_t pin_config = {
    .bck_io_num = I2S_BCLK,
    .ws_io_num = I2S_LRC,
    .data_out_num = I2S_DOUT,
    .data_in_num = I2S_PIN_NO_CHANGE
  i2s_set_pin(I2S_PORT, &pin_config);
  // Set up Serial Monitor
  Serial.println("Generating dynamic sine wave on MAX98357A amplifier");
  // Set up I2S
  i2s_install();
  i2s_setpin();
  i2s_start(I2S_PORT);
  // Buffer to hold the audio data
  int16_t buffer[64];
  // Generate dynamic sine wave (with changing frequency and amplitude)
  for (int i = 0; i < 64; i++) {
    // Generate sine wave with current frequency and amplitude
    float sample = sinf(2.0f * M_PI * currentFrequency * i / sampleRate);
    buffer[i] = (int16_t)(sample * currentAmplitude);  // Convert float to 16-bit integer
  // Send the buffer to the I2S amplifier
  size_t bytesWritten;
  i2s_write(I2S_PORT, &buffer, sizeof(buffer), &bytesWritten, portMAX_DELAY);
  // Adjust frequency and amplitude for the next loop iteration
  currentFrequency += frequencyStep * direction;
  currentAmplitude += amplitudeStep * direction;
  // Change direction of frequency and amplitude when reaching limits
  if (currentFrequency > 880.0 || currentFrequency < 220.0) {
    direction = -direction;  // Reverse direction when frequency reaches upper or lower limit
  if (currentAmplitude > 5000 || currentAmplitude < 1000) {
    direction = -direction;  // Reverse direction when amplitude reaches upper or lower limit
.zip   AS-Speaker-Dynamic-wave.zip (Size: 1.38 KB / Downloads: 522)
.zip   AS-Speaker-Dynamic-wave.ino.merged.zip (Size: 192.38 KB / Downloads: 464)
