10-22-2024, 01:30 AM
This code controls 3 WS2812 RGB LEDs connected to GPIO 15 on an ESP32-S3.
Each LED will be set to blue with adjustable brightness.
The Adafruit NeoPixel library is used to communicate with the WS2812 LEDs.
Hardware setup:
- WS2812 RGB LEDs are connected to GPIO 15 (data pin).
- Total number of LEDs: 3.
#include <Adafruit_NeoPixel.h>
// Create an instance of the Adafruit_NeoPixel class
// Parameters: number of LEDs (3), data pin (GPIO 15), LED type (NEO_GRB with 800 KHz communication)
Adafruit_NeoPixel rgb_display = Adafruit_NeoPixel(3, 15, NEO_GRB + NEO_KHZ800);
// Initialize the NeoPixel library and prepare the LEDs for use
rgb_display.begin();
rgb_display.setPixelColor(uint16_t n, uint32_t c);
This function sets the color of a specific LED.
Parameters:
- n: The LED number (starting from 0).
- c: The color to set the LED to, in hexadecimal (0x0000ff = blue in RGB format).
// Set the first LED (LED 0) to blue
rgb_display.setPixelColor(0, (0x0000ff)); // Blue color for the first LED (index 0)
rgb_display.setBrightness(100); // Set brightness to 100 out of 255
rgb_display.show(); // Update the LED to reflect the change
// Set the second LED (LED 1) to blue
rgb_display.setPixelColor(1, (0x0000ff)); // Blue color for the second LED (index 1)
// Set the third LED (LED 2) to blue
rgb_display.setPixelColor(2, (0x0000ff)); // Blue color for the third LED (index 2)
LED_WS2812B-3pcs.zip (Size: 879 bytes / Downloads: 469)
LED_WS2812B.ino.merged.zip (Size: 177.55 KB / Downloads: 437)
