"KCS" v3.0.3 firmware for A32 Pro controller
v3.0.3 improvement:
1. Fix the problem that mqtt custom port does not take effect
2. Fix the problem of missing comma separator when mqtt returns json
3. Fix the problem that the mqtt command does not support the simultaneous processing of multiple commands
4. Fixed mqtt instructions run_rf, run_ir, set_beep returning wrong json format
.zip   KCS_A32PRO_V3.0.3.zip (Size: 999.62 KB / Downloads: 465)
