Threads: 1
Hi,
I am very interested in getting an M30 for monitoring the various circuits in my home. Some circuits only draw a 1-2A, some 8-10A, some 20-24A.
Can you please provide a list of suitable CT clamps that will work with the M30 for a various range of currents?
Ideally model numbers and specifications so we can source them directly if required.
Many thanks,
Ben
Threads: 1,560
it's OK, we have used many this type CT sensor. In the video, it is just an example of using DC resistant transformers in situations where the quality of the power grid is very poor. The quality of the general power grid is not bad.
Threads: 1,560
because need customize change many resistance on PCB. about 60pcs of resistance, if you can replace by youself.
if made by KinCony, MOQ=100pcs of M30, we can produce it. also need use by 200A KCS firmware file.
Threads: 1,560
Replacing 60pcs of resistors does that mean replacing 2 resistors per channel for the regular 30 channels? -- Yes
Would the 250A CT work for the L1/L2/L3 pins without modification? -- Not need, only need change hardware for current input ports.
Threads: 0
03-04-2025, 06:13 AM
(This post was last modified: 03-04-2025, 06:14 AM by chickenlegcat.)
I think I misunderstood what L1/L2/L3 are for. Are they to measure the voltage of each phase?
If I want to measure the current of the L1/L2/L3 grid connections, would I need to dedicate 3 of the normal channels and replace 6 resistors?
