11-28-2024, 11:41 AM
* Description:
* This Arduino program reads the state of two 16-channel PCF8575 I/O expanders
* and prints the state of all input pins (1-24) to the Serial Monitor. The state of
* each pin is represented as a bit in a 24-bit value, where each bit corresponds
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x24 for inputs 1-16, 0x26 for inputs 17-24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
#define I2C_SDA 8 // Define SDA pin
#define I2C_SCL 18 // Define SCL pin
// Set I2C addresses
PCF8575 pcf8575_IN1(0x24); // The I2C address of the first PCF8575 (inputs 1-16)
PCF8575 pcf8575_IN2(0x26); // The I2C address of the second PCF8575 (inputs 17-24)
// Initialize both PCF8575 modules
pcf8575_IN1.begin();
pcf8575_IN2.begin();
Serial.println("KinCony F24 24 channel input state 0:ON 1:OFF");
uint32_t state = 0; // Use a 32-bit variable to store the state of all 24 pins
// Read the state of each pin from the first PCF8575 (inputs 1-16)
for (int pin = 0; pin < 16; pin++) {
if (pcf8575_IN1.read(pin)) {
state |= (1UL << pin); // Set the bit for the active pin (inputs 1-16)
// Read the state of each pin from the second PCF8575 (inputs 17-24, corresponding to pins 0-7)
for (int pin = 0; pin < 8; pin++) {
if (pcf8575_IN2.read(pin)) {
state |= (1UL << (pin + 16)); // Set the bit for the active pin (inputs 17-24)
// Print the state of all 24 inputs in binary format
delay(500); // Delay 500ms
2-digital-input.zip (Size: 976 bytes / Downloads: 435)
