[arduino code examples for F24]-05 Read free GPIO state
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 48
* - GPIO 47
* - GPIO 21
* - GPIO 15
* - GPIO 14
* - GPIO 13
* - GPIO 12
* - GPIO 40
* Hardware Requirements:
#define GPIO_PIN_48 48
#define GPIO_PIN_47 47
#define GPIO_PIN_21 21
#define GPIO_PIN_15 15
#define GPIO_PIN_14 14
#define GPIO_PIN_13 13
#define GPIO_PIN_12 12
#define GPIO_PIN_40 40
  while (!Serial);      // Wait for the serial monitor to open
  pinMode(GPIO_PIN_48, INPUT);
  pinMode(GPIO_PIN_47, INPUT);
  pinMode(GPIO_PIN_21, INPUT);
  pinMode(GPIO_PIN_15, INPUT);
  pinMode(GPIO_PIN_14, INPUT);
  pinMode(GPIO_PIN_13, INPUT);
  pinMode(GPIO_PIN_12, INPUT);
  pinMode(GPIO_PIN_40, INPUT);
  bool currentState[8];
  currentState[0] = digitalRead(GPIO_PIN_48);
  currentState[1] = digitalRead(GPIO_PIN_47);
  currentState[2] = digitalRead(GPIO_PIN_21);
  currentState[3] = digitalRead(GPIO_PIN_15);
  currentState[4] = digitalRead(GPIO_PIN_14);
  currentState[5] = digitalRead(GPIO_PIN_13);
  currentState[6] = digitalRead(GPIO_PIN_12);
  currentState[7] = digitalRead(GPIO_PIN_40);
  for (int i = 0; i < 8; i++) {
      Serial.print("GPIO ");
      Serial.print(i == 0 ? GPIO_PIN_48 :
                   i == 1 ? GPIO_PIN_47 :
                   i == 2 ? GPIO_PIN_21 :
                   i == 3 ? GPIO_PIN_15 :
                   i == 4 ? GPIO_PIN_14 :
                   i == 5 ? GPIO_PIN_13 :
                   i == 6 ? GPIO_PIN_12 : GPIO_PIN_40);
      Serial.print(" changed to ");
      // Update the previous state
.zip   5-free-gpio-state.zip (Size: 1.05 KB / Downloads: 496)
