11-28-2024, 11:50 AM
* This Arduino program demonstrates how to display text on an SSD1306 128x64 OLED display using the U8g2 library.
* The program draws two lines of text on the display:
* - The first line is "KINCONY" in a larger font.
* - The second line is "www.kincony.com" in a smaller font.
* The display is connected via I2C (software implementation) with:
* - SCL (clock) on pin IO18
* - SDA (data) on pin IO8
* The display's I2C address is set to 0x3C.
#include <U8g2lib.h> // Include the U8g2 library for controlling the OLED display
#include <Wire.h> // Include the Wire library for I2C communication
// Initialize the display using the software I2C method (SCL = IO18, SDA = IO8)
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, 18, 8, U8X8_PIN_NONE); // Screen rotation: U8G2_R0
// Function to display page 1 content
void page1() {
// Set font size 18 for the larger "KINCONY" text
u8g2.setFont(u8g2_font_timR18_tf); // Use the Times Roman font, size 18
u8g2.setFontPosTop(); // Set the text position at the top of the display
u8g2.setCursor(5, 0); // Position the cursor at coordinates (5, 0)
u8g2.print("KINCONY"); // Display the text "KINCONY" on the screen
// Set font size 12 for the smaller "www.kincony.com" text
u8g2.setFont(u8g2_font_timR12_tf); // Use the Times Roman font, size 12
u8g2.setCursor(0, 40); // Position the cursor at coordinates (0, 40)
u8g2.print("www.kincony.com"); // Display the text "www.kincony.com"
// Set the I2C address for the display to 0x3C
u8g2.setI2CAddress(0x3C*2); // I2C address shift for 8-bit format
u8g2.begin();
// Enable UTF-8 character printing for the display
u8g2.enableUTF8Print(); // Allow UTF-8 encoded text to be printed
// Main loop function, continuously runs after setup()
// Begin the display drawing process
u8g2.firstPage(); // Prepare the first page for drawing
do {
// Call the page1() function to draw content on the display
page1();
} while (u8g2.nextPage()); // Continue to the next page until all pages are drawn
10-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 458)
