11-28-2024, 11:51 AM
* This program reads 24 input states from two PCF8575 I/O expanders and
* controls a corresponding 24-channel relay module.
* When an input pin is LOW, the corresponding relay is turned ON (LOW means ON for the relay).
* When the input pin is HIGH, the corresponding relay is turned OFF.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - Input I2C Address 1 (inputs 1-16): 0x24
* - Input/Relay I2C Address 2 (inputs 17-24 and relays 1-8): 0x26
* - Relay I2C Address 3 (relays 9-24): 0x25
#include <Wire.h> // I2C communication
#include <PCF8575.h> // Library to control the PCF8575 I/O expander
// Define I2C pins
#define SDA 8 // SDA pin
#define SCL 18 // SCL pin
// I2C addresses for the PCF8575 modules
#define INPUT_I2C_ADDRESS_1 0x24 // I2C address for the first input PCF8575 module (inputs 1-16)
#define INPUT_RELAY_I2C_ADDRESS_2 0x26 // I2C address for inputs 17-24 and relays 1-8
#define RELAY_I2C_ADDRESS_3 0x25 // I2C address for relays 9-24
PCF8575 pcf8575_IN1(INPUT_I2C_ADDRESS_1); // Create an object for the first input PCF8575 (inputs 1-16)
PCF8575 pcf8575_IN2(INPUT_RELAY_I2C_ADDRESS_2); // Create an object for the second input PCF8575 (inputs 17-24 and relays 1-8)
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS_3); // Create an object for the relay PCF8575 (relays 9-24)
Wire.begin(SDA, SCL);
// Initialize input and relay modules
pcf8575_IN1.begin(); // For inputs 1-16
pcf8575_IN2.begin(); // For inputs 17-24 and relays 1-8
pcf8575_RL.begin(); // For relays 9-24
// Turn off all relays at the start (LOW means OFF)
for (int i = 0; i < 8; i++) {
pcf8575_IN2.write(i, LOW); // Turn off relays 1-8
pcf8575_RL.write(i, LOW); // Turn off relays 9-24
Serial.println("System started: Input state controlling 24 relays");
// Read and control relays 1-16
bool inputState = pcf8575_IN1.read(i); // Read input i from the first input module
if (inputState) {
pcf8575_RL.write(i, HIGH); // If input is HIGH, turn the corresponding relay OFF
} else {
pcf8575_RL.write(i, LOW); // If input is LOW, turn the corresponding relay ON
// Read and control relays 17-24 (shared with second input module)
bool inputState = pcf8575_IN2.read(i + 8); // Read input 17-24 from the second input module (pins 8-15)
if (inputState) {
pcf8575_IN2.write(i, HIGH); // If input is HIGH, turn the corresponding relay OFF (1-8)
} else {
pcf8575_IN2.write(i, LOW); // If input is LOW, turn the corresponding relay ON (1-8)
// Delay for 500 milliseconds
delay(500);
11-input-trigger-output.zip (Size: 1.11 KB / Downloads: 477)
