[arduino code examples for F24]-12 How to control one relay
* This program controls a 24-channel relay board via two PCF8575 I/O expanders.
* It toggles relay 24 every 2 seconds and prints its status via the serial port.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Relay 24 is controlled through the first PCF8575 (I2C_ADDRESS_R1).
#include <Wire.h>        // Include the Wire library for I2C communication
#include <PCF8575.h>     // Include the PCF8575 library to control the I/O expander
#define SDA 8            // Define the SDA pin
#define SCL 18           // Define the SCL pin
#define TOGGLE_DELAY 2000  // Define the toggle delay time (2 seconds)
// Set I2C addresses of the PCF8575 modules
#define I2C_ADDRESS_R1 0x25 // I2C address of the first PCF8575 module (for relays 9-24)
#define I2C_ADDRESS_R2 0x26 // I2C address of the second PCF8575 module (for relays 1-8)
PCF8575 pcf8575_R1(I2C_ADDRESS_R1); // Create a PCF8575 object for the first module (for relays 9-24)
PCF8575 pcf8575_R2(I2C_ADDRESS_R2); // Create a PCF8575 object for the second module (for relays 1-8)
bool relay24State = HIGH; // Initialize relay 24 state to OFF (assuming HIGH is OFF)
  Wire.begin(SDA, SCL); // SDA on GPIO 8, SCL on GPIO 18 (according to your board's configuration)
  // Initialize serial communication for debugging
  Serial.println("PCF8575 Relay 24 Toggle Program: Starting...");
  // Initialize the PCF8575 modules
  pcf8575_R1.begin();
  pcf8575_R2.begin();
  // Ensure that all relays are turned off initially (set all pins HIGH)
    pcf8575_R1.write(i, HIGH); // Set relays 9-24 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R2.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)
  // Toggle relay 24 state (relay 24 corresponds to pin 15 on pcf8575_R1)
  relay24State = !relay24State; // Toggle the state
  pcf8575_R1.write(15, relay24State); // Write the new state to relay 24
  // Print the current state of relay 24 to the serial port
  if (relay24State == LOW) {
    Serial.println("Relay 24 is ON");
  } else {
    Serial.println("Relay 24 is OFF");
  // Wait for 2 seconds before toggling again
  delay(TOGGLE_DELAY);
.zip   12-control-one-relay.zip (Size: 1.09 KB / Downloads: 550)
So, can I connect a VEML 7700 Vin/logic 3-5V sensor to the F24?
SDA and SCL are present, as well as 5V GND and 3V GND.
Should it work?
yes, just need you write your own arduino code. if you want use i2c extend module.
