Speaker Not Working
Sad
Hello guys, I’ve spent a week trying to solve the following problem: the speaker doesn’t work in any way. I’ve tried many methods to get it working, such as reinstalling the software, reinstalling Home Assistant, and reinstalling everything from scratch. The voice activation command “Hey Jarvis” works, but the response is not heard through the speaker. I’m not sure if I’m doing something wrong or if the speaker is simply faulty. I’m attaching screenshots and a video showing how I have everything set up. I hope you can help me. Thank you.
VIDEO:  https://youtu.be/3dvJ8tbW9W8
VIDEO2: https://youtu.be/EIVSB3mJAF8
Let me know if you need more information or anything else.
.txt   logs_jarvis2_compile.txt (Size: 143.54 KB / Downloads: 623)
.txt   jarvis.yaml.txt (Size: 3.98 KB / Downloads: 578)
here have two speaker arduino demo code, you can use it test your speaker hardware whether work well.
[arduino code examples for AS]-03 how to output simple wave to speaker by MAX98357A
[arduino code examples for AS]-04 how to output dynamic wave to speaker by MAX98357A
just download the BIN file to KinCony AS by USB cable. after re power on , if you can hear the sound from speaker, that means hardware well. if hardware is OK, then you need check with your home assistant setting.
It seems I've received a defective speaker. After following your instructions, the speaker still doesn't produce any sound and online research also didn't yield any results, as it appears to be malfunctioning even when checked with a multimeter for continuity and resistance, as shown in the video. It looks like I was sent a faulty item.
You can see everything in the video that follows:
https://youtu.be/flitb0OU4nQ
If you have any other suggestions or would like me to run any tests, please let me know.
Thanks
Do you order from KinCony official shop.
send us your order number, don't worry. we will re send you a new KinCony AS.
(12-05-2024, 10:34 AM)admin Wrote: Do you order from KinCony official shop.
Yes, I have purchased from your website: https://shop.kincony.com/
KinCony IoT Order #1404
OK, we will re send one to you. after sent, will send you tracking number.
(12-05-2024, 11:57 AM)admin Wrote: OK, we will re send one to you. after sent, will send you tracking number.
Thank you very much for your help and service.
package re sent on today, tracking number: UJ858967562YP
