[arduino code examples for G1]-01 Read digital input ports state
* Description:
* This Arduino program reads the state of a 16-channel PCF8575 I/O expander
* each pin is represented as a bit in a 16-bit value, where each bit corresponds
* Pin Definitions:
* - SDA: GPIO 12
* - SCL: GPIO 11
* - PCF8575 I2C Address: 0x24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
#define I2C_SDA 12  // Define SDA pin
#define I2C_SCL 11  // Define SCL pin
// Set I2C address
PCF8575 pcf8575_IN1(0x24); // The I2C address of the PCF8575
    pcf8575_IN1.begin(); // Initialize the PCF8575
    Serial.println("KinCony G1 16CH input state 0:ON  1:OFF"); //actually PCB used 12 buttons, reset 4CH digital input free
    uint16_t state = 0;
    for (int pin = 0; pin < 16; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   1-digital-input.zip (Size: 875 bytes / Downloads: 375)
.zip   1-digital-input.ino.merged.zip (Size: 189.81 KB / Downloads: 380)
