12-06-2024, 01:32 AM
* GPIO Status Monitoring with Change Detection
* Additional Functionality:
* - The program now monitors 11 GPIO pins, not just the previously listed ones.
* - GPIO pins include: GPIO 15, 16, 17, 40, 13, 14, 21, 4, 5, 6, 7.
* - For each pin, whenever its state changes (from HIGH to LOW or vice versa), the new state is printed to the serial monitor.
* GPIO Pins Monitored:
* - GPIO 15
* - GPIO 16
* - GPIO 17
* - GPIO 40
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 4
* - GPIO 5
* - GPIO 6
* - GPIO 7
* Hardware Requirements:
* - Connect the pins to appropriate devices or pull them to HIGH/LOW for testing.
* - Ensure that the ESP32-S3 is powered and connected to a serial monitor to observe the output.
* How it works:
* - The setup function initializes the serial communication and configures the GPIO pins as inputs.
* - The loop function continuously checks the state of each GPIO pin.
* - If a pin's state changes, the new state is printed to the serial monitor, along with the corresponding pin number.
* - The program uses a delay to prevent excessive serial prints, which can be adjusted as necessary.
#define GPIO_PIN_15 15
#define GPIO_PIN_16 16
#define GPIO_PIN_17 17
#define GPIO_PIN_40 40
#define GPIO_PIN_13 13
#define GPIO_PIN_14 14
#define GPIO_PIN_21 21
#define GPIO_PIN_4 4
#define GPIO_PIN_5 5
#define GPIO_PIN_6 6
#define GPIO_PIN_7 7
bool prevState[11] = {false, false, false, false, false, false, false, false, false, false, false};
while (!Serial); // Wait for the serial monitor to open
pinMode(GPIO_PIN_15, INPUT);
pinMode(GPIO_PIN_16, INPUT);
pinMode(GPIO_PIN_17, INPUT);
pinMode(GPIO_PIN_40, INPUT);
pinMode(GPIO_PIN_13, INPUT);
pinMode(GPIO_PIN_14, INPUT);
pinMode(GPIO_PIN_21, INPUT);
pinMode(GPIO_PIN_4, INPUT);
pinMode(GPIO_PIN_5, INPUT);
pinMode(GPIO_PIN_6, INPUT);
pinMode(GPIO_PIN_7, INPUT);
bool currentState[11];
currentState[0] = digitalRead(GPIO_PIN_15);
currentState[1] = digitalRead(GPIO_PIN_16);
currentState[2] = digitalRead(GPIO_PIN_17);
currentState[3] = digitalRead(GPIO_PIN_40);
currentState[4] = digitalRead(GPIO_PIN_13);
currentState[5] = digitalRead(GPIO_PIN_14);
currentState[6] = digitalRead(GPIO_PIN_21);
currentState[7] = digitalRead(GPIO_PIN_4);
currentState[8] = digitalRead(GPIO_PIN_5);
currentState[9] = digitalRead(GPIO_PIN_6);
currentState[10] = digitalRead(GPIO_PIN_7);
for (int i = 0; i < 11; i++) {
Serial.print("GPIO ");
Serial.print(i == 0 ? GPIO_PIN_15 :
i == 1 ? GPIO_PIN_16 :
i == 2 ? GPIO_PIN_17 :
i == 3 ? GPIO_PIN_40 :
i == 4 ? GPIO_PIN_13 :
i == 5 ? GPIO_PIN_14 :
i == 6 ? GPIO_PIN_21 :
i == 7 ? GPIO_PIN_4 :
i == 8 ? GPIO_PIN_5 :
i == 9 ? GPIO_PIN_6 : GPIO_PIN_7);
Serial.print(" changed to ");
// Update the previous state
2-free-gpio-state.zip (Size: 1.42 KB / Downloads: 731)
2-free-gpio-state.ino.merged.zip (Size: 179.82 KB / Downloads: 698)
