Check about connections
Good afternoon,
I want to control 2 different devices fans with 0-10v capabilities of one KC868-A4S but I'm not sure about wiring.
For the first fan from AFL Motors (file 122) these are the connections that I plan :
 - 0-10 VDC yellow on fan with AO1 on KC868-A4S
 - GND blue on fan with GND after AO1 on KC868-A4S
for the second fan from Aermec (file 22) these are the connections that I plan :
 - 0-10V IN V2 blue on Aermec with AO2 on KC868-A4S
 - 0V V1 grey on Aermec with GND after AO1 on KC868-A4S
Am I right or wrong ? If I'm wrong, what are the right connections ?
Thanks
.pdf   122.pdf (Size: 122.57 KB / Downloads: 603)
.pdf   22.pdf (Size: 226.52 KB / Downloads: 538)
connection is ok, but need to test with fan.
Thank You very much.
