Dimensions/drawings of board layouts?
The schematics for the boards are very useful to have and much appreciated - thankyou for providing these.
Do you also have drawings of the boards available? (i.e. the .brd file, rather than just the .sch file), or just the dimensioned outlines and screw holes, at least? It would be very useful when trying to integrate them into custom enclosures.
Thanks.
UPDATE: I found this thread, which has what I need for the A6. Now I just need the same for the A4, A8, and A16 boards Smile https://www.kincony.com/forum/showthread.php?tid=2808
when we have free time ,we can make it.
No drawings available ?
3D-models ?
It's very important for embedding the controllers into own cases.
It's better to export the PCB outline with holes into a .DWG, .DFX. And solid 3D-model .STEP is very interesting.
Altium designer can do it easily.
we can supply PCB CAD file for size. if it's useful for DIYers.
(04-28-2025, 10:39 AM)admin Wrote: we can supply PCB CAD file for size. if it's useful for DIYers.
Yes, thanks in advance ! Please, for A2, A4, A6 at least, but maybe better for all, if in one forum thread - it will be very useful for getting
KC868-A2 PCB layout CAD file: https://www.kincony.com/forum/showthread.php?tid=8023
KC868-A4 PCB layout CAD file: https://www.kincony.com/forum/showthread.php?tid=8024
KC868-A6 PCB layout CAD file: https://www.kincony.com/forum/showthread.php?tid=8025
(04-28-2025, 12:46 PM)admin Wrote: KC868-A2 PCB layout CAD file: https://www.kincony.com/forum/showthread.php?tid=8023
Thanks ! Please, add the height info of the fully soldered boards.
Are 3D-models .STEP files possible ?
As i can understand A4 PCB is fully the same as A6: 148 х 105 x 22 mm (height PCB + top = 20 mm, bottom soldering = 2 mm height).
Holes are 125 х 97 mm.
3D-outline of PCB is attached.
.zip   KC868_A6_3D_step.zip (Size: 30.18 KB / Downloads: 536)
