Threads: 1
Hi there, i have just installed latest KCS firmware (V2.2.8) on my KC868-A16 and i noticed that besides the ntp time offset problem, after soft restarting the board the lan does not work. The only solution is to power cycle the board. On the wifi, connection re-establishes normally. I guess it's a software issue besause ESPHOME reboots and re-establishes on LAN successfully. Plz consider fixing in on next update. Thank you in advance![url=https://www.kincony.com/forum/showthread.php?tid=7077][/url]
Threads: 1,576
after download firmware, you need re power on of your board.
Threads: 1,576
about LAN8720, need hardware reboot.
Threads: 1
So how that does not affect ESPHOME firmware but only KCS?
Threads: 1,576
do you means firmware download by ESPHome not need to hardware re power on. But download by KCS firmware, MUST need re power on of board?
Yes, That's true. ESPHome as same as arduino IDE, after download will auto reset hardware. But ESP32 download tool can't do that.
