Threads: 1
Hi!
I am new here and I am having some troubles.
my board is the KC868-A6-v1.3
the firmware I am trying to install is the KCS_KC868_A6_V2.2.8.bin
the flash tool version i s the 3.9.2
My problem is that it flashes it way too fast. In the youtube videos you can clearly see a progress bar and that it takes some time to upload the firmware.
Mine does not, it just go from START>SYNC>DOWNLOAD>FINISH in two seconds. Meanwhile the background shell shows this
is stub and send flash finish
Uploading stub...
Running stub...
Stub running...
FLASH_CRYPT_CNT 0
ABS_DONE_0 False
but no progressbar or uploaded byte info. How can I be sure that the version has been uploaded properly? Might it be the reason why I don't find any AP after reseting it?
thanks!
Image(s)
Threads: 1,546
take a video of your problem, can't see your full screen photo, use video is better.
Threads: 1
No luck with any firmware.
I started using the ESP_EASY_FLASHER and found this log
######2024-12-30######
#######0.04.009#######
######FLASH INFO######
BIN file: KCS_KC868_A6_V2.2.10.bin
COM port: (COM4) USB-SERIAL CH340 (Port_#0008.Hub_#0001)
Baud rate: 115200
######POST FLASH######
No post flash information entered...
######FLASH LOG######
[esptool.exe -vv -cd nodemcu -cb 115200 -cp COM4 -ca 0x00000 -cf "D:\flash_download_tool_3.9.2\flash_download_tool_3.9.2\bin\KCS_KC868_A6_V2.2.10.bin"]
[30/12/2024 9:01:23] esptool v0.4.12 - © 2014 Ch. Klippel <ck@atelier-klippel.de>
[30/12/2024 9:01:23] setting board to nodemcu
[30/12/2024 9:01:23] setting baudrate from 115200 to 115200
[30/12/2024 9:01:23] setting port from to COM4
[30/12/2024 9:01:23] setting address from 0x00000000 to 0x00000000
[30/12/2024 9:01:23] espcomm_upload_file
[30/12/2024 9:01:23] espcomm_upload_mem
[30/12/2024 9:01:23] setting serial port timeouts to 1000 ms
[30/12/2024 9:01:23] opening bootloader
[30/12/2024 9:01:23] resetting board
[30/12/2024 9:01:23] trying to connect
[30/12/2024 9:01:23] flush start
[30/12/2024 9:01:23] setting serial port timeouts to 1 ms
[30/12/2024 9:01:23] flush complete
[30/12/2024 9:01:23] espcomm_send_command: sending command header
[30/12/2024 9:01:23] espcomm_send_command: sending command payload
[30/12/2024 9:01:23] read 0, requested 1
[30/12/2024 9:01:23] espcomm_send_command: receiving 4 bytes of data
[30/12/2024 9:01:23] Uploading 2048576 bytes from D:\flash_download_tool_3.9.2\flash_download_tool_3.9.2\bin\KCS_KC868_A6_V2.2.10.bin to flash at 0x00000000
[30/12/2024 9:01:23] erasing flash
[30/12/2024 9:01:23] size: 1f4240 address: 000000
[30/12/2024 9:01:23] first_sector_index: 0
[30/12/2024 9:01:23] total_sector_count: 501
[30/12/2024 9:01:23] head_sector_count: 16
[30/12/2024 9:01:23] adjusted_sector_count: 485
[30/12/2024 9:01:23] erase_size: 1e5000
[30/12/2024 9:01:23] setting serial port timeouts to 18580 ms
[30/12/2024 9:01:23] warning: espcomm_send_command: didn't receive command response
[30/12/2024 9:01:23] warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
[30/12/2024 9:01:23] closing bootloader
[30/12/2024 9:01:23] error: espcomm_upload_mem failed
[2024-12-30 09:01:23] DONE! BUT WITH (1) ERRORS!
[2024-12-30 09:01:23] The COM port was already in use... the post-flash did not complete.
[2024-12-30 09:01:23] JOB COMPLETED, over and out!
Threads: 1
I found it. I am very sorry for wasting your time. The problem is embarrasing, I forgot to click the checkbox of the bin file.
As soon as I selected, that row went green and it flashed properly.
Again, sorry for bothering you, and thanks a lot.
