Threads: 4
How to set up an KC868-A8M that is connected via Ethernet in WiFi access point mode in order for devices to connect to it at the same gatewaygatewa as the main router? The devices will be wifi esp32 which will work together in HA. For example, my main network is 192.168.1.1 and I want the WiFi distribution network (KC868-A8M) to be in the same range 192.168.1…… Thanks
Threads: 1,204
download KCS firmware, set wifi mode=STA, input your router's ssid and password. after reboot, esp32 will connect to your router.
Threads: 4
01-04-2025, 03:09 PM
(This post was last modified: 01-04-2025, 03:37 PM by kulibin.)
Does the KC868-A4S module also have the same LAN. LAN8720 chip?
