KC868-H32 Relay Controller REV:2.4 Problem after firmware update
Hello, today I ordered from your controller for control through the Tuya application, and in this regard I decided to change the firmware version with a new one downloaded from your site following all the steps as described. After the procedure is completed, my kc868-h32 is no longer the same. outputs 2 and 3 flash and the response time of the buttons is unstable. Please give me feedback and if there is the original version of my device, could you provide it to me?
I installed the firmware H32B_V508_230921
that is "H32B" controller, not your "H32" . they are different product.
here is original firmware for KC868-H32
.zip   2--H32_Relay_32.zip (Size: 11.8 KB / Downloads: 435)
if you want KC868-H32 controller work with tuya app, you should add tuya adapter, here is video tour:
https://youtu.be/z67pRMLb4Rc
Hello! I can't log into the app, login konstantin-19.11@mail.ru, I forgot my password, what should I do?
kincony cloud server stop use in 2024-12-31
https://www.kincony.com/forum/showthread.php?tid=5437
