01-15-2025, 03:06 AM
#include "Arduino.h"
// Define RS232 pins
#define RS232_TXD 9 // TX pin
#define RS232_RXD 10 // RX pin
// Define RS232 communication
HardwareSerial RS232(1); // Use UART1
// Initialize RS232 serial communication
RS232.begin(9600, SERIAL_8N1, RS232_RXD, RS232_TXD); // Baud rate 9600, 8 data bits, no parity, 1 stop bit
Serial.begin(115200); // Debug serial communication
Serial.println("RS232 Communication Initialized");
static unsigned long lastSendTime = 0;
// Send a string to RS232 every 5 seconds
if (millis() - lastSendTime >= 5000) {
RS232.println("This is KinCony A6v3");
Serial.println("Sent: This is KinCony A6v3");
lastSendTime = millis();
// Check if data is available from RS232
while (RS232.available()) {
String receivedData = RS232.readStringUntil('\n'); // Read data from RS232
RS232.println(receivedData); // Echo the received data back to RS232
Serial.println("Received and echoed: " + receivedData); // Print the received data to the debug console
RS232.zip (Size: 659 bytes / Downloads: 490)
RS232.ino.merged.zip (Size: 184.5 KB / Downloads: 490)
