[arduino code examples for A16v3]-08 Ethernet W5500 chip work with TCP Server mode
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN  15
#define W5500_RST_PIN 1
#define W5500_INT_PIN 2
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
IPAddress ip(192, 168, 3, 55);       // Static IP address
IPAddress subnet(255, 255, 255, 0);   // Subnet mask
IPAddress gateway(192, 168, 3, 1);    // Default gateway
IPAddress dns(192, 168, 3, 1);        // DNS server address
EthernetServer server(4196);
  while (!Serial) {
  digitalWrite(W5500_RST_PIN, LOW);  // Reset the W5500 module
  delay(100);                       // Wait for reset to complete
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
.zip   8-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 540)
.zip   8-Ethernet-W5500.ino.merged.zip (Size: 188.94 KB / Downloads: 514)
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* DNS: 192.168.3.1
#include <SPI.h>
  while (!Serial) {
  server.begin();
  if (client) {
        server.write(c);
    client.stop();
I used this code, but it doesn`t work. I tried other simple Ethernet-sketches, but they don`t work. I already tried to use <Ethernet3.h> and <Ethernet_Generic.h> libraries, but they both also didn`t help. I used correct IPAddress ip, subnet, gateway and dns values, that i tried with arduino before. I changed mac too. Help, please!
we install this ethernet arduino library.
