Threads: 1,302
you can try to use S1, S2 for RXD, TXD
Threads: 1,302
S3 and S4 can't use for RXD, TXD. ONLY use for INPUT signal.
Threads: 3
It is working with S3 and S4. Thanks.
Here is my sample ESPHome config.
captive_portal:
## LD2420 Sensor
- platform: ld2420
has_target:
## LD 2420
- platform: ld2420
moving_distance:
uart:
tx_pin: 33 #S4 KC868-A8
rx_pin: 32 #S3 KC868-A8
baud_rate: 115200
parity: NONE
stop_bits: 1
ld2420:
text_sensor:
- platform: ld2420
fw_version:
select:
- platform: ld2420
operating_mode:
number:
- platform: ld2420
presence_timeout:
name: Detection Presence Timeout
min_gate_distance:
name: Detection Gate Minimum
max_gate_distance:
name: Detection Gate Maximum
# See "Number" section below for detail
gate_select:
name: Select Gate to Set
still_threshold:
name: Set Still Threshold Value
move_threshold:
name: Set Move Threshold Value
button:
- platform: ld2420
apply_config:
factory_reset:
restart_module:
revert_config:
