Threads: 1
Hi All,
I have an A16S board, which has a problem. LAN is randomly freezing, board itself keep functional, but network is going down.
Ethernet cable replug solves the issue. (or rebooting the unit)
What can be the reason behind? Makes my automations really unstable.
Thank you in advance,
Zoltan
Threads: 1,593
do you use ESPHome or KCS firmware?
can you change a ethernet cable and router's port.
Threads: 1,593
CAT5 cable is OK. i think you can use a separate power supply for KC868-A16S for testing.
Threads: 1,593
you can contact with seller where you bought from. when you bought? where you bought from?
Threads: 1,593
can you take a video of your problem, send video to whatsapp number: +86-15381188302 we will test it.
Threads: 1
I found a workaround now. One channel of the device was used to switch a motor (a ventilation fan) what caused the problem.
Strange because it was also behind a full isolated relay. Line and Null was switched by an external relay. Board just only sent line for signal.
I took it out, and using it with a sonoff mini switch. Freezing is gone.
Do you have any idea, why this is happened?
Threads: 1,593
the motor work with AC or DC power ?
if AC motor, you need add KinCony RC snubber to reduce the interference signal
