01-19-2025, 02:10 AM
* RS485 Communication Test
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 14
#define RS485_TXD 13
while (!Serial);
// Send a test message
rs485Serial.println("Hello from KinCony T16M!");
// Wait for a short period
delay(1000);
String receivedMessage = "";
char c = rs485Serial.read();
receivedMessage += c;
// Print the received message
Serial.print("Received: ");
delay(2000);
3-RS485-Test.zip (Size: 763 bytes / Downloads: 674)
3-RS485-Test.ino.merged.zip (Size: 184.35 KB / Downloads: 660)
