Threads: 1
Hi I am using KC868 AIO installed for my smart home project, I would like to interface 4 ws2812b led strips how can I do that? Which of the pins can be used as data pins for the same. An example circuit and Yaml also will be appreciated.
Regards
Krushi
Threads: 1,204
GPIO5 and GPIO14 can use for ws2812b. there is free gpio terminal you can use it.
Threads: 1
I would like to connect 4 independent Led strips for different locations, so I might need more than 2 pins. Are there any more pins that I can use for other led strips. Can any other pins on KC868 AIO be used as GPIO?
Threads: 1,204
KC868-AIO only have 2 free gpio. if you want use more LED strip for WS2812B, you can add another kincony board, such as KinCony S3, there are many free gpio ports can use.
