Threads: 9
Dear friend, can you please make a video on how to set up and connect a thermostat and heated floor on the A24 board, perhaps you have already done something similar before, I think many will be interested in how to do this, thank you
Threads: 1,204
what's your thermostat and heated interface? how to control it?
Threads: 9
I will buy the thermostat that you say is compatible with kincony a24 and will be able to control the heated floor.
I have heated floor under the laminate (170W per square meter)
I don't understand your question "how to control it?"
I just want to connect the heated floor to kincony a24 and control it using a thermostat compatible with kincony A24
Threads: 1,204
if only ON/OFF, you can use A24 relay output to control it.
