02-15-2025, 05:43 AM
friendly_name: a6v3
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
wifi:
ssid: "KinCony"
password: "a12345678"
ap:
ssid: "A6 Fallback Hotspot"
password: "GLdHSsZr1p96"
captive_portal:
sda: 12
scl: 11
pcf8574:
address: 0x24
address: 0x22
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 17
rx_pin: 18
- id: uart_2 #RS232
baud_rate: 9600
debug:
direction: BOTH
after:
timeout: 10ms
tx_pin: 9
rx_pin: 10
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
- platform: uart
uart_id: uart_1
- platform: uart
uart_id: uart_2
data: [0x55, 0x66, 0x77, 0x88, 0x99]
pcf8574: pcf8574_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
##pull-up resistance on PCB
number: 15
number: 16
- platform: adc
pin: 4
name: "A6v3 A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 5
name: "A6v3 A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 6
name: "A6v3 A3 Current"
update_interval: 5s
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 7
name: "A6v3 A4 Current"
update_interval: 5s
attenuation: 11db
filters:
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "KinCony A6v3");
gp8403:
voltage: 10V
output:
- platform: gp8403
gp8403_id: my_gp8403
channel: 0
- platform: gp8403
channel: 1
light:
- platform: monochromatic
output: gp8403_output_1
output: gp8403_output_2
web_server:
port: 80
A6v3-HA.txt (Size: 5.11 KB / Downloads: 624)
