access control panel input number control OUTPUT by wiegand yaml for ESPhome
here is demo config file for access control panel. control OUTPUT1 or OUTPUT3 by INPUT NUMBER "101#" and "102#" by touch panel.
esp32:
  board: esp32dev
  framework:
    type: arduino
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
   - id: bus_a
     sda: 4
     scl: 16
pcf8574:
  - id: 'pcf8574_hub_out_1'  # for output channel 1-16
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_in_3'  # for output channel 33-38  + (input 49-58)
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for input channel 17-32
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_in_3'  # for input channel 33-48
    i2c_id: bus_a
    address: 0x23
    pcf8575: true
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_in_3
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0:
      number: 8
      mode: OUTPUT
    pin_s1:
      number: 9
      mode: OUTPUT
    pin_s2:
      number: 10
      mode: OUTPUT
    pin_s3:
      number: 11
      mode: OUTPUT
  - platform: adc
    pin: 36
    update_interval: never
    attenuation: 11db
  - platform: adc
    pin: 39
    update_interval: 50s
    attenuation: 11db
  - platform: adc
    pin: 34
    attenuation: 11db
  - platform: adc
    pin: 35
    attenuation: 11db
  - platform: cd74hc4067
    sensor: adc36
    number: 1
    sensor: adc36
    number: 2
    sensor: adc36
    number: 3
    sensor: adc36
    number: 4
    sensor: adc36
    number: 5
    sensor: adc36
    number: 6
    sensor: adc36
    number: 7
    sensor: adc36
    number: 8
    sensor: adc36
    number: 9
    sensor: adc36
    number: 10
    sensor: adc36
    number: 11
    sensor: adc36
    number: 12
    sensor: adc36
    number: 13
    sensor: adc36
    number: 14
    sensor: adc36
    number: 15
    sensor: adc36
# Individual inputs
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_3
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
pca9685:
    frequency: 500
output:
  - platform: pca9685
    pca9685_id: 'pca9685_hub'
    channel: 0
  - platform: pca9685
    channel: 1
  - platform: pca9685
    channel: 2
  - platform: pca9685
    channel: 3
  - platform: pca9685
    channel: 4
  - platform: pca9685
    channel: 5
  - platform: pca9685
    channel: 6
  - platform: pca9685
    channel: 7
  - platform: pca9685
    channel: 8
  - platform: pca9685
    channel: 9
  - platform: pca9685
    channel: 10
  - platform: pca9685
    channel: 11
  - platform: pca9685
    channel: 12
  - platform: pca9685
    channel: 13
  - platform: pca9685
    channel: 14
  - platform: pca9685
    channel: 15
light:
  - platform: monochromatic
    output: PWM0
    output: PWM1
    output: PWM2
    output: PWM3
    output: PWM4
    output: PWM5
    output: PWM6
    output: PWM7
    output: PWM8
    output: PWM9
    output: PWM10
    output: PWM11
    output: PWM12
    output: PWM13
    output: PWM14
    output: PWM15
  - platform: rgbw
    red: PWM1
    green: PWM2
    blue: PWM3
    white: PWM4
wiegand:
  - id: mykeypad
    d0: GPIO14
    d1: GPIO5
    on_key:
      - lambda: ESP_LOGI("KEY", "received key %d", x);
    on_tag:
      - lambda: ESP_LOGI("TAG", "received tag %s", x.c_str());
    on_raw:
      - lambda: ESP_LOGI("RAW", "received raw %d bits, value %llx", bits, value);
key_collector:
  - id: pincode_reader
    source_id: mykeypad
    min_length: 3
    max_length: 3
    end_keys: "#"
    end_key_required: true
    back_keys: "*"
    clear_keys: "C"
#    allowed_keys: "0123456789"
    timeout: 5s
    on_progress:
      - logger.log:
          format: "input progress: '%s', started by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]
    on_result:
      - logger.log:
          format: "input result: '%s', started by '%c', ended by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)", "(end == 0 ? '~' : end)" ]
      - if:
          condition:
            lambda: |-
              return x=="101";
          then:
            switch.toggle: aio_light1
      - if:
          condition:
            lambda: |-
              return x=="102";
          then:
            switch.toggle: aio_light2
    on_timeout:
      - logger.log:
          format: "input timeout: '%s', started by '%c'"
ESPHome yaml file download:
.txt   KC868-AIO-ESPHome-wiegand.txt (Size: 21.93 KB / Downloads: 453)
