B16 ESPHome yaml for home assistant with tuya
  friendly_name: b16
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
external_components:
  - source:
      type: git
      ref: v1.1.0
# logger:
#   hardware_uart: USB_SERIAL_JTAG
  encryption:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
pcf8574:
  - id: 'pcf8574_hub_out_1'  # for output channel 1-16
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
uart:
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: byxtsco8rwt4x8km
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b16_output01"
      number: 1
      mode: OUTPUT
    dp_id: 2
    internal: true
    bind_switch_id: "b16_output02"
      number: 2
      mode: OUTPUT
    dp_id: 3
    internal: true
    bind_switch_id: "b16_output03"
      number: 3
      mode: OUTPUT
    dp_id: 4
    internal: true
    bind_switch_id: "b16_output04"
      number: 4
      mode: OUTPUT
    dp_id: 5
    internal: true
    bind_switch_id: "b16_output05"
      number: 5
      mode: OUTPUT
    dp_id: 6
    internal: true
    bind_switch_id: "b16_output06"
      number: 6
      mode: OUTPUT
    dp_id: 101
    internal: true
    bind_switch_id: "b16_output07"
      number: 7
      mode: OUTPUT
    dp_id: 102
    internal: true
    bind_switch_id: "b16_output08"
      number: 8
      mode: OUTPUT
    dp_id: 103
    internal: true
    bind_switch_id: "b16_output09"
      number: 9
      mode: OUTPUT
    dp_id: 104
    internal: true
    bind_switch_id: "b16_output10"
      number: 10
      mode: OUTPUT
    dp_id: 105
    internal: true
    bind_switch_id: "b16_output11"
      number: 11
      mode: OUTPUT
    dp_id: 106
    internal: true
    bind_switch_id: "b16_output12"
      number: 12
      mode: OUTPUT
    dp_id: 107
    internal: true
    bind_switch_id: "b16_output13"
      number: 13
      mode: OUTPUT
    dp_id: 108
    internal: true
    bind_switch_id: "b16_output14"
      number: 14
      mode: OUTPUT
    dp_id: 109
    internal: true
    bind_switch_id: "b16_output15"
      number: 15
      mode: OUTPUT
    dp_id: 110
    internal: true
    bind_switch_id: "b16_output16"
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
    dp_id: 111
    bind_binary_sensor_id: b16_input01
    internal: true
      number: 1
      mode: INPUT
    dp_id: 112
    bind_binary_sensor_id: b16_input02
    internal: true
      number: 2
      mode: INPUT
    dp_id: 113
    bind_binary_sensor_id: b16_input03
    internal: true
      number: 3
      mode: INPUT
    dp_id: 114
    bind_binary_sensor_id: b16_input04
    internal: true
      number: 4
      mode: INPUT
    dp_id: 115
    bind_binary_sensor_id: b16_input05
    internal: true
      number: 5
      mode: INPUT
    dp_id: 116
    bind_binary_sensor_id: b16_input06
    internal: true
      number: 6
      mode: INPUT
    dp_id: 117
    bind_binary_sensor_id: b16_input07
    internal: true
      number: 7
      mode: INPUT
    dp_id: 118
    bind_binary_sensor_id: b16_input08
    internal: true
      number: 8
      mode: INPUT
    dp_id: 119
    bind_binary_sensor_id: b16_input09
    internal: true
      number: 9
      mode: INPUT
    dp_id: 120
    bind_binary_sensor_id: b16_input10
    internal: true
      number: 10
      mode: INPUT
    dp_id: 121
    bind_binary_sensor_id: b16_input11
    internal: true
      number: 11
      mode: INPUT
    dp_id: 122
    bind_binary_sensor_id: b16_input12
    internal: true
      number: 12
      mode: INPUT
    dp_id: 123
    bind_binary_sensor_id: b16_input13
    internal: true
      number: 13
      mode: INPUT
    dp_id: 124
    bind_binary_sensor_id: b16_input14
    internal: true
      number: 14
      mode: INPUT
    dp_id: 125
    bind_binary_sensor_id: b16_input15
    internal: true
      number: 15
      mode: INPUT
    dp_id: 126
    bind_binary_sensor_id: b16_input16
    internal: true
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 40
      number: 7
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B16");
download yaml file:
.txt   B16-HA.txt (Size: 13.84 KB / Downloads: 631)
I have purchased a B16. And I run this YAML file to flash. These are the errors I have received. Attached is the log.
.txt   logs_b16_run.txt (Size: 28.98 KB / Downloads: 367)
1. WARNING Using `switch.SWITCH_SCHEMA` is deprecated and will be removed in ESPHome 2025.11.0. Please use `switch.switch_schema(...)` instead. If you are seeing this, report an issue to the external_component author and ask them to update it. https://developers.esphome.io/blog/2025/...recations/. Component using this schema: tuya_wifi_mcu
and then this:
2.
Compiling .pioenvs/b16/FrameworkArduino/FunctionalInterrupt.cpp.o
.piolibdeps/b16/Tuya_WiFi_MCU_SDK/src/TuyaWifi.cpp: In constructor 'TuyaWifi::TuyaWifi()':
.piolibdeps/b16/Tuya_WiFi_MCU_SDK/src/TuyaWifi.cpp:34:33: error: no matching function for call to 'TuyaUart:Confusedet_serial(USBCDC*)'
    tuya_uart.set_serial(&Serial);
In file included from .piolibdeps/b16/Tuya_WiFi_MCU_SDK/src/TuyaWifi.h:19,
                      from .piolibdeps/b16/Tuya_WiFi_MCU_SDK/src/TuyaWifi.cpp:15: .piolibdeps/b16/Tuya_WiFi_MCU_SDK/src/TuyaUart.h:46:10: note: candidate: 'void TuyaUart:Confusedet_serial(HardwareSerial*)'
                                void set_serial(TY_UART *serial);
.piolibdeps/b16/Tuya_WiFi_MCU_SDK/src/TuyaUart.h:46:10: note: no known conversion for argument 1 from 'USBCDC*' to 'HardwareSerial*'
*** [.pioenvs/b16/libe10/Tuya_WiFi_MCU_SDK/TuyaWifi.cpp.o] Error 1
========================= [FAILED] Took 238.15 seconds =========================
later we will upload new file, because esphome have updated.
(07-03-2025, 08:05 AM)admin Wrote: later we will upload new file, because esphome have updated.
Still waiting for the new YAML file please. Thank you  Smile
tested compile with esphome 2025.6.3 without any issue.
(07-09-2025, 11:51 AM)admin Wrote: tested compile with esphome 2025.6.3 without any issue.
ok, thank you. I have tried again and seems that all is well.
Sir, I'm enjoying my B16. Thank you for giving us the opportunity to play with smart home by your consistent innovations. I even more appreciate your sharing of knowledge. Thank you!
I'd like to just say this for this warning keeps coming up. We are still getting this messages every time we compile our YAML file. It is not an error, but just a warning. I thought you might like to update it.
Again, I enjoy your products very much. You at Kincony are so innovative, hardworking and generous to share knowledge. And you always answer very quickly.
Thank you. Have a good day!
yes, we will update this in future, because ESPHome have some new update. But now it also can compile yaml file without issue.
