02-22-2025, 02:08 AM
* This Arduino program implements communication between ESP32 and the Tuya module
* and responds according to the predefined commands.
* Functionality:
* 1. When the ESP32 receives a heartbeat packet (55 AA 00 00 00 00 FF),
* it sends a heartbeat response (55 AA 03 00 00 01 00 03).
* 2. When the ESP32 receives a product information request (55 AA 00 01 00 00 00),
* it sends a product information response (55 AA 03 01 ...).
* 3. When the ESP32 receives a work mode request (55 AA 00 02 00 00 01),
* it sends a work mode response (55 AA 03 02 00 03 10 1C 14 47).
* 4. When the ESP32 receives a network status request (55 AA 00 03 00 01 00 03),
* it sends a network status response (55 AA 03 03 00 00 05).
* 5. Subsequent heartbeat packets (55 AA 00 00 00 00 FF) are responded to with
* (55 AA 03 00 00 01 01 04).
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
// Define the GPIO pins for TXD and RXD used for serial communication
#define TXD_PIN 16
#define RXD_PIN 17
#define BAUD_RATE 9600
// Heartbeat response: 55 AA 03 00 00 01 00 03
// Product info response with a detailed payload (e.g., firmware version, product name, etc.)
// Work mode response: 55 AA 03 02 00 03 10 1C 14 47
uint8_t workModeResponse[] = {0x55, 0xAA, 0x03, 0x02, 0x00, 0x03, 0x10, 0x1C, 0x14, 0x47};
// Network status response: 55 AA 03 03 00 00 05
// Subsequent heartbeat response: 55 AA 03 00 00 01 01 04
// Check if data is available from the Tuya module
if (tuyaSerial.available()) {
uint8_t incomingPacket[7]; // Array to store the received packet
size_t bytesRead = tuyaSerial.readBytes(incomingPacket, 7); // Read 7 bytes from Tuya
if (bytesRead < 7) {
Serial.println("Incomplete packet received. Waiting for remaining bytes...");
delay(50); // Delay to allow more data to be received
if (bytesRead >= 7) break;
// If still less than 7 bytes, discard the incomplete packet
Serial.println("Error: Incomplete packet discarded.");
return;
// Debug: Print the received packet for logging
Serial.print("Received packet: ");
for (size_t i = 0; i < 7; i++) {
Serial.print(incomingPacket[i], HEX);
Serial.print(" ");
Serial.println();
// Call the function to process the received packet
} else {
// If the header is invalid, discard the packet and flush the buffer
Serial.print("Error: Invalid packet header. Data received: ");
for (size_t i = 0; i < bytesRead; i++) {
Serial.print(" ");
Serial.println();
// Delay to avoid CPU overuse
delay(100);
// Function to process the received packet and send the appropriate response
// Ensure the packet size is 7 and the header is valid
// Determine the command in the packet (packet[2])
switch(packet[2]) {
case 0x00:
sendPacket(heartBeatResponse, sizeof(heartBeatResponse));
} else if (packet[3] == 0x01 && packet[4] == 0x00 && packet[5] == 0x00 && packet[6] == 0x00) {
sendPacket(productInfoResponse, sizeof(productInfoResponse));
} else if (packet[3] == 0x02 && packet[4] == 0x00 && packet[5] == 0x00 && packet[6] == 0x01) {
sendPacket(workModeResponse, sizeof(workModeResponse));
} else if (packet[3] == 0x03 && packet[4] == 0x00 && packet[5] == 0x01 && packet[6] == 0x00) {
sendPacket(netStatusResponse, sizeof(netStatusResponse));
break;
default:
break;
// Function to send the response packet to the Tuya module
// Send the packet via UART to Tuya module
// Debug: Print the sent packet for logging
Serial.print(packet[i], HEX);
Serial.print(" ");
Serial.println();
9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 723)
9-tuya-wifi-config.ino.merged.zip (Size: 184.93 KB / Downloads: 715)
