02-26-2025, 10:05 PM
I'm trying to install a Wika A-10 Pressure Sensor/Transmitter 8-30VDC 4-20mA P# 13361091. This is the first time I've used a 4-20ma sensor. I've used other 0-5V and 0-10V sensors before with voltage dividers and have been successful.
Can you help me understand how the A1 and A2 Analog Inputs on the B16M work to convert the 4-20ma signal into a voltage and what I should use for the gain? ChatGPT is trying to explain it to me but it describes using a 250ohm shunt resistor. How do I know what internal shunt resistor(s) have been used to convert the signal to be readable by the internal ads1115 chip?
I will be using 12VDC to excite the pressure sensor which is rated for 8-30VDC. The Wika test report shows that the sensor should produce 4ma at 0 bar and 20ma at 2.5 bar (36.2595 PSI). Here is a snapshot of my YAML code for esphome so far:
# ADC
ads1115:
- address: 0x48
# SENSORS
- platform: ads1115
name: "Filter Pressure Voltage"
web_server:
sorting_group_id: sortgroup_hidden_sensors
device_class: voltage
multiplexer: "A0_GND"
gain: 6.144
resolution: 16_BITS
unit_of_measurement: "V"
icon: mdi:lightning-bolt-circle
internal: false
update_interval: 5s
- platform: template
name: "Filter Pressure Gauge"
web_server:
sorting_group_id: sortgroup_sensors
device_class: pressure
lambda: |-
// Pressure Sensor Model: Wika A-10 Pressure Transmitter 8-30VDC 4-20mA P# 13361091
// Convert the voltage (1V to 5V) to PSI (0 to 36.2595 PSI)
return (id(filter_pressure_voltage).state / 5.0) * 36.2595;
unit_of_measurement: "PSI"
accuracy_decimals: 2
icon: mdi:gauge
internal: false
update_interval: 5s
# ADC
ads1115:
- address: 0x48
# SENSORS
- platform: ads1115
web_server:
gain: 6.144
resolution: 16_BITS
internal: false
update_interval: 5s
web_server:
lambda: |-
icon: mdi:gauge
internal: false
update_interval: 5s
