because now esp32 inside is our test firmware.
you need download KCS v2 firmware to use. or you config it by esphome. the USB driver for MAC download at here: https://www.wch-ic.com/downloads/CH341SER_EXE.html
A6 no free GPIO for ethernet module.
(03-03-2025, 10:35 PM)admin Wrote: because now esp32 inside is our test firmware.
Understood, need to flash esphome. However, I don't see any USB device (besides my keyboard and hub) when I connect the KCS.
I tried:
- 3 different known good cables (1 A to C, 2 C to C)
- Connect to hub and connect directly to a port in my computer
- Power cycle, hold button.
According to the instructions for the ch341, I should see a USB device with VID 1a86, but it is not there.
Thanks for your answer, understood about the demo firmware.
I do not see a USB device. According to the documentation in the CH341 driver, I should see an USB device with VID 1a86. But that doesn't show up. All the USB devices are accounted for.
I tried 3 USB cables, of which 2 are known to work. I tried direct to my laptop and through USB hub. I tried power cycling.
I should have mentioned that before posting, I tried with several known good cables, including the one I use to sync my phone and the one I use to stream audio.
if you really can't find your USB port when tested with high quality usb-c cable. tell me your order number and where you buy from, re send you a new KC868-A6 board.
(03-06-2025, 09:19 AM)admin Wrote: if you really can't find your USB port when tested with high quality usb-c cable. tell me your order number and where you buy from, re send you a new KC868-A6 board.
AliExpress Kincony controller store 3047682950312739.
