Threads: 3
I have 2 boards installed using KS2 firmware: K868-a32 and k868-a16s
What's the best way to set them up, i would like to use home assistant and MQTT but still want light to work in case home assistant breaks.
Should i setup boards using IFTTT, and only integrate MQTT for some scene automations, remote control and reading relay states?
Threads: 1,561
1. use by esphome config yaml file for home assistant.
2. integrate to home assistant by mqtt.
you can use any way for home assistant integration.
Threads: 3
can i use rs485 to communicate between boards? a16s -> a32, and a32 -> a16s
a16s.yaml
PHP Code: # RS485 Modbus Setup uart: id: uart_a16s tx_pin: GPIO33 rx_pin: GPIO32 baud_rate: 19200 debug: direction: BOTH dummy_receiver: false after: timeout: 1s sequence: - lambda: UARTDebug::log_hex(direction, bytes,' ');
modbus: - uart_id: uart_a16s id: modbus_a16s_client send_wait_time: 200ms - uart_id: uart_a16s id: modbus_a16s_server role: server
modbus_controller: # Client role - to initiate communication with a32 - id: a16s_client_controller modbus_id: modbus_a16s_client address: 0x4 # Address of a32's server update_interval: 1s setup_priority: 100 # Higher priority = earlier execution
# Server role - to respond to a32's requests - modbus_id: modbus_a16s_server address: 0x2 # a16s's server address
switch: - platform: modbus_controller modbus_controller_id: a16s_client_controller # References the controller ID defined in hardware.yaml name: "a32_output1" id: "a32_output1" address: 0 # 0:relay1 1:relay2 ... 31:relay32 register_type: coil bitmask: 1
a32.yaml
PHP Code: uart: - id: uart_a32 tx_pin: GPIO14 rx_pin: GPIO16 baud_rate: 19200 debug: direction: BOTH dummy_receiver: false after: timeout: 1s sequence: - lambda: UARTDebug::log_hex(direction, bytes,' ');
modbus: - uart_id: uart_a32 id: modbus_a32_client send_wait_time: 200ms - uart_id: uart_a32 id: modbus_a32_server role: server
modbus_controller: # Client role - to initiate communication with a16s - id: a32_client_controller modbus_id: modbus_a32_client address: 0x2 # Address of a16s's server update_interval: 2s setup_priority: 50 # Lower priority = later execution
# Server role - to respond to a16s's requests - modbus_id: modbus_a32_server address: 0x4 # a32's server address switch: - platform: modbus_controller modbus_controller_id: a32_client_controller # References the controller ID defined in hardware.yaml name: "a16s_output1" id: "a16s_output1" address: 0 # 0:relay1 1:relay2 ... 5:relay16 register_type: coil bitmask: 1
modbus errors
PHP Code: [size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#ff00ff][C][modbus_controller:350]: Address: 0x04[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#ff00ff][C][modbus_controller:351]: Max Command Retries: 4[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#ff00ff][C][modbus_controller:352]: Offline Skip Updates: 0[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#00ffff][D][uart_debug:114]: >>> 04 01 00 00 00 20 3D 87[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#ffff00][W][modbus:125]: Modbus CRC Check failed! 90D1!=00[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#00ffff][D][modbus_controller:040]: Modbus command to device=4 register=0x00 no response received - removed from send queue[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#ffff00][W][modbus:125]: Modbus CRC Check failed! 90D1!=00[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#ffff00][W][modbus:125]: Modbus CRC Check failed! 90D1!=00[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#00ffff][D][uart_debug:114]: <<< 02 01 00 00 00 10 3D F5 02 01 00 00 00 10 3D F5 02 01 00 00 00 10 3D F5[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#00ffff][D][uart_debug:114]: >>> 04 01 00 00 00 20 3D 87[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:45:59][color=#ffff00][W][modbus:125]: Modbus CRC Check failed! 4E91!=00[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:46:00][color=#00ffff][D][uart_debug:114]: <<< 63 3D 00 00 00 10 3D F5[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:46:00][color=#ffff00][W][modbus_controller:186]: Duplicate modbus command found: type=0x1 address=0 count=32[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:46:00][color=#00ffff][D][uart_debug:114]: >>> 04 01 00 00 00 20 3D 87 04 01 00 00 00 20 3D 87 04 01 00 00 00 20 3D 87 04 01 00 00 00 20 3D 87[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:46:00][color=#ffff00][W][modbus:125]: Modbus CRC Check failed! 90D1!=00[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:46:00][color=#00ffff][D][modbus_controller:040]: Modbus command to device=4 register=0x00 no response received - removed from send queue[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:46:01][color=#ffff00][W][modbus:125]: Modbus CRC Check failed! 90D1!=00[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:46:01][color=#ffff00][W][modbus:125]: Modbus CRC Check failed! 90D1!=00[/color] [/font][/size][size=1][font=SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace][12:46:01][color=#ffff00][W][modbus:125]: Modbus CRC Check failed! 90D1!=00[/color][/font][/size]
Threads: 1,561
what functions you want? can you explain in details.
Threads: 3
03-10-2025, 11:29 AM
(This post was last modified: 03-10-2025, 11:30 AM by mitzuuu89.)
(03-10-2025, 11:11 AM)admin Wrote: what functions you want? can you explain in details.
basically this.. input from one board to trigger output on another board, and vice versa, bidirectional communication.
a16s_input1 -> a32_output1
a32_input1 -> a16s_output1
modbus seems to only work as client-server, so no bidirectional communication
Threads: 1,561
i suggest you download KCS v2 firmware, use IFTTT with customize protocol will be easy.
just IF controller-A DI1 pressed THEN send customize command to controller-B by RS485 or network.
Threads: 3
(03-10-2025, 10:52 PM)admin Wrote: i suggest you download KCS v2 firmware, use IFTTT with customize protocol will be easy.
will try, thank you
i did manage to use esp-now to communicate between boards, but i don't know how stable esp-now is.
Threads: 1,561
use wired way is more stable.
Threads: 9
(03-06-2025, 08:07 AM)mitzuuu89 Wrote: I have 2 boards installed using KS2 firmware: K868-a32 and k868-a16s
That's how I'm doing it, HA if available but with the Kincony boards doing as much as possible natively via IFTTT rules. This way even if HA goes down or disconnects, basic functionality will still be present.
Note that if you want to do anything more complex than very basic stuff you either need to use an external relay to feed a digital output to another digital input to chain IFTTT rules, or wait for updated firmware that implements this change request.
