Threads: 22
I have an issue with my A32 pro :
- when I configure the Esphome yaml file and start controlling the A32 pro by homeassistant, i loose kcs firmeware ( ican’t login kcs web page).
And when i reinstall kcs firmeware, then i loose the control by homeassistant!!
Why is it happening?
Threads: 1,204
ESPHOME and KCS can't work at the same time.
you can download KCS firmware, enable "MQTT auto discovery" function, then A32 Pro will auto integrate to home assistant. Then also work with KCS firmware.
Threads: 22
Great. Now it works well.
Few Questions:
Question 1:
How can I set (for example relay 1+2+3) to turn on for 5 seconds then turn off, at 17:00 O clock , without setting outputs in delay mode.
I want to use it for Windows to let them open at 17:00 O clock for 5 seconds then stop.
The other time of the day I want control them manually.
Question 2 :
I noticed that If i turn on any relay by homeassistant or tuya or homkit, then i can’t turn it off by the manual switch on pcb. Is there away that makes my able to change the state by manual switch?
Threads: 1,204
1. set by IFTTT function, IF timer THEN relay xxxxx.
2. manaul control button design without software, this is used in emergency situations. if you want work as your said, you should connect switch button with digital input ports, that state work with software. THE manual control buttons on the box, when controller is broken, also can work with relay.
