KinCony B16 ESP32-S3 Smart Controller released
KinCony B16 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel relay output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B16 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B16 have I2C bus extender and RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B16 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: B16-1.jpg]
Model No. KinCony B16
Description: KinCony 16 Channel ESP32-S3 Smart Relay Controller – B16
Power supply: 12V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD,I2C,Tuya Module
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
[Image: B16-2.jpg]
Outputs:
16CH relay Outputs, every relay use by MAX AC250V/7A
Inputs:
16CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
1-Wire GPIO: 7CH (with pull-up resistance on PCB)
[Image: B16-3.jpg]
just use by FAT32. i have tested with 64G card, it's ok.
