03-22-2025, 06:26 AM
Hello everyone,
I have an A6 and an A16.
On the A6, an analog sensor (1-5V) is connected to ADC1. The sensor measures the air pressure. Via gear symbol, I defined a calculation, so I don't see the raw value, but the reading in bar:
![[Image: 2025-03-22-07-19-03-Monitor-und-1-weiter...t-Edge.png]](https://i.ibb.co/WNfJJYzw/2025-03-22-07-19-03-Monitor-und-1-weitere-Seite-Pers-nlich-Microsoft-Edge.png)
Via MQTT, only the RAW value is transmitted (see left side of the picture). Is it possible to transmit the calculated value (7.29) and unit (bar), so that a possible home assistant auto discovery also shows the correct unit?
