Threads: 2
I am trying to use one of the outputs to drive a 12v siren directly. I have a 12v power supply, with 12v passing from the input to the 12v terminal on the output block. If I connect my siren to the 12v and output terminal on the block, it doesn't sound properly, and if I measure the voltage across them with a multimeter I am only seeing ~10.5v.
Is this a limitation of the board, or have I wired something wrong?
Threads: 1,235
take a photo of your board , i want see how wire.
Threads: 7
Just for comparison, I'm driving a 12V siren that way without any problems. Having said that I haven't measured the output voltage so it may be running off less than 12V, a lot of alarm devices will run from a voltage range around 9-16V.
Threads: 1,235
your siren one wire connect with OUTPUT-1, another wire should connect to GND, NOT 12v power.
Threads: 2
04-08-2025, 02:28 PM
(This post was last modified: 04-08-2025, 02:29 PM by Knightrider.)
Ah just me being stupid. I already tried wiring the siren between the output and ground, and couldn't get it to work. Turns out that the voltage input to the siren is polarity specific and I had the connection the wrong way round. I also needed to invert the output. Now all working correctly! Thanks.
