Threads: 2
Hi
I need to use other CT with different CT ratio.
In ESPHome I can Change IT.
But need IT in the Webpage (stand alone use).
IS IT planed to integrate IT in the UI?
Or IS the source Code available?
BR
Linus
Threads: 1,277
if you use M16v2 or M30 board, just chose 2000:1 CT clamp sensor, it according to PCB hardware design.
Threads: 2
Hi
I know the HW Design, and can also modify IT.
So the question IS can the SW BE Made more universal.
Would bei interessted for more customer
BR
Linus
Threads: 1,277
04-08-2025, 08:47 AM
(This post was last modified: 04-08-2025, 08:48 AM by admin.)
not only change the software will suitable for different CT sensors.
Threads: 2
04-08-2025, 09:44 AM
(This post was last modified: 04-08-2025, 11:44 AM by Linus68.)
Why Not
IT IS Just the Parameter Like in ESPHome
Have CT 600A/40mA.
This IS compatible with HW.
Only SW Not.
So IT would bei a benefit for the M30 HW to have a universal SW
Threads: 2
Hi
are there any news available?
