"KCS" v3.9.0 firmware BIN file download
v3.9.0 improvement:
1. fixed wifi can't disable in "AP" mode.
2. add support new controller F8 & A2v3 & A8v3 & B8M & TA
.zip   KCS_A2V3_V3.9.0.zip (Size: 1.03 MB / Downloads: 600)
.zip   KCS_A6V3_V3.9.0.zip (Size: 1.01 MB / Downloads: 694)
.zip   KCS_A8V3_V3.9.0.zip (Size: 1.06 MB / Downloads: 637)
.zip   KCS_A16V3_V3.9.0.zip (Size: 1.08 MB / Downloads: 618)
.zip   KCS_A32PRO_V3.9.0.zip (Size: 1.05 MB / Downloads: 662)
.zip   KCS_AG8_V3.9.0.zip (Size: 1.04 MB / Downloads: 621)
.zip   KCS_B8M_V3.9.0.zip (Size: 1.07 MB / Downloads: 632)
.zip   KCS_B16_V3.9.0.zip (Size: 1.07 MB / Downloads: 659)
.zip   KCS_B16M_V3.9.0.zip (Size: 1.07 MB / Downloads: 606)
.zip   KCS_F8_V3.9.0.zip (Size: 1.06 MB / Downloads: 601)
.zip   KCS_F16_V3.9.0.zip (Size: 1.08 MB / Downloads: 590)
.zip   KCS_F24_V3.9.0.zip (Size: 1.08 MB / Downloads: 640)
.zip   KCS_G1_V3.9.0.zip (Size: 1.03 MB / Downloads: 580)
.zip   KCS_KC_TA_V3.9.0.zip (Size: 1.03 MB / Downloads: 622)
.zip   KCS_T16M_V3.9.0.zip (Size: 1.02 MB / Downloads: 625)
new controller "F8 & A2v3 & A8v3 & B8M & TA" will release soon.
(04-10-2025, 01:25 AM)admin Wrote: v3.9.0 improvement:
Just tested it and the WiFi-disable display bug is fixed, the web interface now correctly shows the WiFi status.  However the OLED display still shows the incorrect status, so it shows the WiFi enabled even when it isn't.
The time zone bug is still present, it seems to use UTC no matter what time zone you set.
Also, setting a sensor type + GPIO bricks the board, requiring a reflash.  For example under 'Sensor' set sensor #1 = DHT22, GPIO = 47 (the first option), "Save", and the board will be bricked, even a hardware reset won't work, you need to power cycle and reflash.
Finally, digital inputs seem to be dead, even if I directly connect the GND pin on the connector to, say DI9, the web interface ("Monitor") shows no change.  This is a new v3 board that I haven't tried before so I'm not sure if this is faulty hardware or a software bug, it worked OK with the older v2 I had.  I've tried directly bridging the pins on the board in case there's a problem with the connector and there's no change, it reports the DI input as not closed.
time zone and others will check.
