Threads: 2
Hi
I want to control and dim 24v LED strips using a controller like KC868-A4S. I'm looking for any recommendations for drivers.
I've tried Meanwell ELG-200-24B. But it doesn't turn off completely.
Any inputs are appreciated.
Threads: 1,559
if you want use dimmable led strip, suggest you chose KC868-D16 dimmer controller +24V power driver.
Threads: 2
04-11-2025, 05:53 AM
(This post was last modified: 04-11-2025, 05:55 AM by TMaYaD.)
Unfortunately, I couldn't find any info on how to run esphome on D16.
Additionally I prefer to have single device per area of my home and A4S with 0-10v channels, relays and inputs matches the use case perfectly... If only I could figure out how to actually use the 0-10v output correctly.
I couldn't find the schematic for D16 either. Though I'm not an expert when it comes to electronics, It would help to compare how A4S differs from D16.
Threads: 2
Home assistant aside, I still want to use esphome.
Threads: 1,559
we will design new esp32 dimmer board in this year.
Threads: 5
Why not use the board KC868-AP ?
It's 24 Vdc, so you can connect the ledstrip directly, without any driver.
Only problem maybe is the the limited current of 3A/output channel.
